Question about torque wrench - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-15-2009, 10:51 AM   #1 (permalink)
View hungt1999's Photo Gallery
I want to purchase a torque wrench (the type that clicks at a certain torque setting) so I can torque my lug nuts and other things correctly
The one I am considering is 1/2'' drive, 24'' long with torque settings from 40 to 250 lbs-ft
My question is let's say I want to unbolt something that is stuck really tight, does that mean that I won't be able to apply a torque more than 250 ft-lbs ? in other words, the mechanisms will start slipping once I apply more than 250 lbs-ft and I will never be able to remove the bolt?
hungt1999 is offline   Reply With Quote
Old 10-15-2009, 11:03 AM   #2 (permalink)
Automotive Lighting Guru
gold94corolla's Avatar
Gameroom cash: $291352
View gold94corolla's Photo Gallery
You could remove it using a regular wrench....
gold94corolla is online now   Reply With Quote
Old 10-15-2009, 11:47 AM   #3 (permalink)
so I cannot use the torque wrench as a braker bar to remove something tighter than 250 lbs-ft?
Old 10-15-2009, 01:42 PM   #4 (permalink)
View mvftw's Photo Gallery
Right, torque wrench is 'ON' Only and you must set it back to zero when done...
mvftw is offline   Reply With Quote
Old 10-15-2009, 03:51 PM   #5 (permalink)
Greasewrench's Avatar
View Greasewrench's Photo Gallery
its not really recommended but i've seen people do it. best bet is to use an actual breaker bar or an impact wrench to loosen a really tight fastener. most torque wrenches cost a decent amount of money and should only be used to manually tighten down fastners to an exact degree, u might damage the tool using it any other way. also if the wrench is rated for 250ft lbs of torque and u want to tighten something to more than that amount, u will need to buy a torque wrench with a higher ft- lbs rating capacity.
Greasewrench is offline   Reply With Quote
Old 10-15-2009, 05:04 PM   #6 (permalink)
View kevmac's Photo Gallery
Sounds like your looking at my mountain torque wrench. It works great and does the job. Keep dreaming if you think you will find a better torque than 250 on a 1/2" drive. If You require greater than 250 then guess what, a 1/2" breaker bar won't help either and based on my experience, the torque wrench is much more supported to handle 250 than my 1/2" Husky bar with a cheater. Buy the 250 wrench
...or buy a 3/4" torque wrench for $500.
edit: you should have asked the general section. They have a lot of valuable info on tools.
97' Corolla, CE, 4AFE, 1.6, AT, 4d
kevmac is offline   Reply With Quote
Old 10-15-2009, 11:27 PM   #7 (permalink)
GTChink's Avatar
Gameroom cash: $105050
View GTChink's Photo Gallery
If you're just unbolting something, use a regular wrench or breaker bar and add a pipe over it
1994 Corolla
GTChink is offline   Reply With Quote
Old 10-16-2009, 07:37 AM   #8 (permalink)
Bitter's Avatar
Gameroom cash: $558900
View Bitter's Photo Gallery
using one to loosen things will ruin the calibration, not that cheap ones are finely calibrated to begin with but it'll get worse than it already is.
Old 10-21-2009, 02:44 PM   #9 (permalink)
It's A Facial TN Member!
trife96's Avatar
View trife96's Photo Gallery
yea, don't use it to remove anything. Oh and if your using it only on our cars mainly, try to find one with a lower range than 40-250. Our cars mostly are torqued within 0-100lbs.
I have a nice small 3/8 drive click type. I think it's 0-80lbs and will do every bolt on the Corolla.
www.cardomain.com/ride/2950600
trife96 is offline   Reply With Quote
