Yep, everyone is right. Air in the brake system, or something wrong with the caliper/brake pads (but that's rare to never)
Either you or someone did a bad brake job, you have a loose brake reservoir cap, or you have a damaged brake hose and air is coming in. Check for leaks under the car, bleed the brake system, and check brake hoses for damage.
Is your brake fluid low and needs to be filled, or is it constant?
Cars that I own:
1996 Toyota Corolla DX
1996 Toyota Camry LE
2007 Toyota Camry SE
