how to tighten e brake - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-18-2009, 12:29 AM   #1 (permalink)
rubenm199253's Avatar
View rubenm199253's Photo Gallery
Question how to tighten e brake
1996 corolla standard 1.6 my e brake feels loose and when i brake it sounds like my ebrake is still on??
rubenm199253 is offline   Reply With Quote
Old 10-18-2009, 03:26 AM   #2 (permalink)
Rip The E Brake's Avatar
Gameroom cash: $112690
View Rip The E Brake's Photo Gallery
You should take a lookin side the rear drums. You probably need new brake shoes. If you are hearing scraping noises, your going to need new drums and shoes.
Corolla Number TWO
OLD: Corolla 1- 96 4AFE, AE101 w/ 225k Miles orig. motor, 129k trans. - TOTALED.
NEW: Corolla 2- 96 4AFE, AE101 w/ 161k Miles on motor and trans.
Rip The E Brake is offline   Reply With Quote
Old 10-18-2009, 09:42 AM   #3 (permalink)
Bitter's Avatar
Gameroom cash: $558900
View Bitter's Photo Gallery
correct, check the shoes inside the drums. if they're not worn then they may just need adjustment.
Old 10-19-2009, 07:33 AM   #4 (permalink)
k thanks yea thats what i am hearing! and it is so embarrasing because it has gotten pretty loud is there a link you can send me on how to do this or do you not recommend me doing it?
Last edited by rubenm199253; 10-19-2009 at 07:35 AM. Reason: forgot to add something
Old 10-19-2009, 07:54 AM   #5 (permalink)
Brake shoes are kind of tricky.
Here ya go.
Video Part 1 - http://www.wonderhowto.com/how-to/vi...orolla-162637/
Video Part 2 - http://www.wonderhowto.com/how-to/vi...olla-162637_2/
If the video doesnt load, just refresh the page.
Enjoy. Maybe someone can stick this.
Corolla Number TWO
Old 10-19-2009, 08:24 AM   #6 (permalink)
View hungt1999's Photo Gallery
Like others said, check the shoes and drums, replace the shoes if the thickness is less than 1-2mm range or so. You might need to adjust the star wheel cog so that when you put the drum and wheel, it spins with a bit of drag, not to much, about one free revolution after you let go the wheel
after that you can tighten the hand brake lever tension by removing the center trim and adjust the two nuts. It should have 4-7 clicks
hungt1999 is offline   Reply With Quote
Old 10-19-2009, 10:56 AM   #7 (permalink)
If he is hearing scraping and grinding, they need to be replaced. Just watch the above linked videos and you'll be good to go.
Corolla Number TWO
Old 10-19-2009, 08:10 PM   #8 (permalink)
Automotive Lighting Guru
gold94corolla's Avatar
Gameroom cash: $291352
View gold94corolla's Photo Gallery
Well, there is a way to tighten the E-brake, but I guess that's not the problem
gold94corolla is online now   Reply With Quote
Old 10-20-2009, 01:01 AM   #9 (permalink)
thanks yea im replacing them this weekend!
Old 10-20-2009, 09:37 PM   #10 (permalink)
It's A Facial TN Member!
trife96's Avatar
View trife96's Photo Gallery
true, there is a way to tighten them more...but our e-brake also self adjusts as the pads wear down.
www.cardomain.com/ride/2950600
trife96 is offline   Reply With Quote
