After the car gets warmed up, some smoke (or steam) would rise from the engine bay. After I shut the engine off, the smoke would get pretty intense for awhile until the entire engine cools down.
The smoke is odorless (as far as I can smell anyway), and looks like steam from a kettle. I've never seen the "blue smoke" that comes from burning oil, so I can't really tell.
It is coming from the engine side closer to the firewall, underneath the intake manifold.
I checked the fluids, and it wasn't loosing any significant amount. Its a 250k car, so I wasn't too surprised that it burns oil. The caveat is that I do have to top off the coolant every so often. The stuff inside the radiator (from looking down the cap) is always full. The only thing I top off is the overflow tank. And it isn't a heavy leak at any rate.
What is "every so often"? every 3 days?, every 3 months?
Does the smoke/ steam smell like antifreeze?
Oil buring on the exhaust would smell nasty and toxic. Look for condensation on the ceiling of the hood after the smoke/ steam is gone to see if it is from water if not sure.
Every month or so. I do live in the high deserts of Calif.
The smell from the engine is one of exhaust (I have a cracked header). I'll look for condensation, will update after I take a drive.
Hmm... found two separate issues. This car has a leaking tranny/torque-converter, cracked header, and now a leaking power steering and leaking radiator. I'm already looking for a new car and am hoping to find quick / cheap fixes to keep this car alive long enough for me to find a new one. Ideas?
1) The burning smoke turns out to be power steering fluid (ATF). I shouldn't be leaking any, and I just checked and saw that I lost a measurable amount.
2) The coolant isn't leaking from hoses, it is from a crack in the radiator. I have no idea how I missed this.
Everything you said sounds minor except the transmission issue. Check that to see if it is worth fixing. You might be able to take the radiator to a shop to weld pretty easily. If not perfectly maintained, that radiator could easily boil over driving the hills between LA and Palmdale daily in 105F summer heat if that's the case.
The shop quoted me 2k for transmission. That's probably more than the car is worth. I've been checking ATF religiously to make sure it didn't drop too much.
How much would a new radiator cost? Is it DIY-able?
