Crankshaft Issues - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-18-2009, 10:55 AM   #1 (permalink)
View polecat999's Photo Gallery
Canada Crankshaft Issues
I have a 1993 Toyota Corolla 4dr sedan LE w/ 4AFE engine, 3 speed auto trans. The crankshaft has snapped outside the engine at the steering/alternator pulley. Can this be repaired, or am I looking at engine replacement/swap? Any recommendations would be appreciated. Thanks.
polecat999 is offline   Reply With Quote
Old 10-18-2009, 11:01 AM   #2 (permalink)
Bitter's Avatar
Gameroom cash: $558900
View Bitter's Photo Gallery
a good picture would help.
Old 10-18-2009, 11:47 AM   #3 (permalink)
on full afterburner
Gameroom cash: $1344797
LE's only came with the 1.8L 7A-FE engine.
If yours has the 4A-FE and 3-speed auto, then it's not an LE.
Old 10-18-2009, 06:06 PM   #4 (permalink)
Official TN Toaster
iToaster's Avatar
Gameroom cash: $348295
View iToaster's Photo Gallery
He's from Canada... apparently things work differently up there. Anyway, polecat999, I'd say if the crankshaft breaks the engine is pretty much shot unless you want to go through a lot of trouble and actually replace it.
1995 Corolla DX - 7A-FE - 5 Speed - 8K1
2000 Celica GT-S - Supercharged 2ZZ-GE - 6 Speed - 3P0
RIP white Corolla
iToaster is offline   Reply With Quote
Old 10-18-2009, 10:32 PM   #5 (permalink)
Canada Swap 4AFE
I gather it's best to replace the engine, then.
I've had my eye on the JDM 4AGE Black top 20 Valve engine. If I understand correctly, the 4AGE will bolt directly into the engine compartment without engine mount modification. The automatic tranny (also included with the JDM engine I'm considering) may require the modification of one mount (check me on this, though). Does the JDM 4AGE meet Canadian emission requirements? I remember reading somewhere that the EGR valve and some other emission equipment is missing. If the engine doesn't meet Canadian requirements, can it be modified into compliance? If emission modification required, is this procedure easy (ie. use EGR from 4AFE, etc)? Thanks to all for your input.
Cheers.
Old 10-18-2009, 10:42 PM   #6 (permalink)
Official TN Toaster
iToaster's Avatar
I'm not familiar with the Canadian laws about this kind of thing, but if you're required to have an inspection you'll fail. It is correct that the blacktop doesn't have some common emission hardware, and you can't put any of it on the blacktop. If you can swap, the engine will fit without modification to the mounts (and in your case the tranny mount will work too), but you still need to splice wiring harnesses and get custom lines for power steering and AC.
RIP white Corolla
Old 10-18-2009, 10:51 PM   #7 (permalink)
View keyboardracer's Photo Gallery
I never heard of crank shaft snapped . Or is it the bolt holding the crank pulley to the crank shaft break apart?
keyboardracer is offline   Reply With Quote
Old 10-18-2009, 11:54 PM   #8 (permalink)
Canada crankshaft damage
Looks to be crankshaft end that extends outside of the engine (crankshaft pulley bolt threads into damaged section of crankshaft).
Old 10-19-2009, 12:48 AM   #9 (permalink)
retiredat44's Avatar
View retiredat44's Photo Gallery
does it use the key (is that a woodruff key? it's been along time since I remeember which type of key it's called.._)
They key could have somehow loosed up and the pulley spun..
1989 Toyota Corolla SR5, Carb.
1993 Camry LE
retiredat44 is offline   Reply With Quote
