Which light bulbs in center console? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-19-2009, 11:21 PM   #1 (permalink)
View pdculbert's Photo Gallery
Hello,
I have a 1996 Corolla DX. The light bulb that illuminates the buttons for the hazards and defrost has burned out. I took the trim off a few months back to put in a new stereo head unit, and it was kind of a pain, so I am not looking forward to doing it again. Does anyone know the bulb types for the hazards/defrost button bulb and those that illuminate the climate controls? I would rather buy the bulbs before I take it off so I can get it right back on, and I figure it would be a good idea to replace them all when they are accessible.
Thanks.
pdculbert is offline   Reply With Quote
Old 10-19-2009, 11:32 PM   #2 (permalink)
View msrdude's Photo Gallery
Originally Posted by pdculbert View Post
Hello,
Thanks.
I believe the hazard/defrost is a 74 type bulb. Note, when you buy the bulbs, you have to buy the ones that comes with the circle cover thinge because it does not come apart. I tried to remove the bulb from the holder thing and I broke it, and had to go to junkyard to steal one. Those bulbs rarely go out and suggest you go to junkyard and just put in your pocket. Its sooo tiny. Same goes with the instrument cluster lights. But for the climate controls (fan speed, heat control, etc) has no cover so you can pull out. I believe that is 74 as well. Best if you go to junkyard like i said.
Cars that I own:
1996 Toyota Corolla DX
1996 Toyota Camry LE
2007 Toyota Camry SE
msrdude is offline   Reply With Quote
Old 10-20-2009, 11:49 AM   #3 (permalink)
Automotive Lighting Guru
gold94corolla's Avatar
Gameroom cash: $291352
View gold94corolla's Photo Gallery
lol.... that panel is soooo easy to remove and put on, I'm not sure why you'd have any trouble...
so, your temperature control light works? It is just those two buttons that don't?? Those are always burned out it seems lol.
BUT.... those are NOT 74-type bulbs.... 74 are waaay too big. Here is a picture of the bulbs out of the switches (they simply unscrew and pull out):
I believe that they are 10 mm wide...... there are 3 kinds when you go to buy. 8 mm, 10 mm, 12 mm..... These are either 8 or 10, I don't remember.....
You can buy the bulbs in regular or LED on this page
http://autolumination.com/74.htm
Go half way down and look for "Japanese OEM Neo - Wedge LED Instrument Panel Bulbs Type A, B & C"
gold94corolla is online now   Reply With Quote
Old 10-20-2009, 02:50 PM   #4 (permalink)
Official TN Toaster
iToaster's Avatar
Gameroom cash: $348295
View iToaster's Photo Gallery
Those are 4 mm NeoWedge bulbs, which are extremely hard to find. I bought 2 LED varieties from superbrightleds.com so that I wouldn't have to deal with them burning out.
1995 Corolla DX - 7A-FE - 5 Speed - 8K1
2000 Celica GT-S - Supercharged 2ZZ-GE - 6 Speed - 3P0
RIP white Corolla
iToaster is offline   Reply With Quote
Old 10-20-2009, 11:16 PM   #5 (permalink)
View Zain's Photo Gallery
i was also thinking about replacing my blue color lights form the guage cluster with some LED bulbs
but m not sure if its gona work or not
Zain is offline   Reply With Quote
Old 10-20-2009, 11:57 PM   #6 (permalink)
Yeah, it looks nice for sure
Old 10-21-2009, 08:09 AM   #7 (permalink)
I want to improve my car!
View abrown0809's Photo Gallery
Exactly what LEDS did you use for your cluster? I've always wanted to change the bulbs to LEDS but I heard that sometimes the light output isn't even.
abrown0809 is offline   Reply With Quote
Old 10-21-2009, 08:39 AM   #8 (permalink)
that look sweet
what LED bulbs u used
i will be replacing my dome light bulb and the one behind tha ac knobs and stuff too
Old 10-21-2009, 10:05 AM   #9 (permalink)
Thanks, let's see..
IF you have the removeable bulbs in the gauge cluster, you can simply swap out the 194-type bulbs with LEDs. If not, you will need to get the base as well for each bulb.
Go here
http://autolumination.com/194.htm
Find this bulb
Buy 3 of them if you have the tach cluster..... buy 4 of them if you have the non-tach cluster.
Those LEDs are perfect for the gauges. They have the 5 LEDs on top that have a 180-degree wide angle, so they light perfectly into the diffusers. You do not need LEDs with side-ways facing LEDs here.
For the A/C control bulb... I'm not sure how you can do that one, since the bulb sticks tightly into a clear plastic diffuser. So, the bulb you get would need to be the same size and have light out of all directions evenly. SMT are good LEDs.
Something like this
I'm not sure though... you can't really remove the diffuser and have the light come out..... in my case, I just put my own LEDs behind each symbol.
You can use SMT LEDs for the dome lights and for the warning indicators in the gauge cluster (I used blue and red ones like shown).
Old 10-21-2009, 10:50 AM   #10 (permalink)
Rip The E Brake's Avatar
Gameroom cash: $112690
View Rip The E Brake's Photo Gallery
Gold, when I get a new cluster, I want to pay you to swap out all my LED's and shit.
Corolla Number TWO
OLD: Corolla 1- 96 4AFE, AE101 w/ 225k Miles orig. motor, 129k trans. - TOTALED.
NEW: Corolla 2- 96 4AFE, AE101 w/ 161k Miles on motor and trans.
Rip The E Brake is offline   Reply With Quote
Old 10-21-2009, 11:55 AM   #11 (permalink)
HAHA you're funny.... it is very very easy man!! Take out old bulbs.... put in new ones! I mean, if you can get the cluster swapped and working, you can put in the LEDs
Old 10-21-2009, 11:40 PM   #12 (permalink)
i also need to change the bulb behind the ac control
its kind of loose
when i hit it it starts working
soo can u help me which type bulb will go in tht?
Old 10-22-2009, 12:03 AM   #13 (permalink)
HAHAHA the infamous A/C control bulb that works after you hit it...... we have 2 toyotas, and they both had that problem LOL.
Definitely look at my post with all the blue LED bulbs.... I already listed some that I would try there! But I can't say that any will fit though.
Old 10-22-2009, 09:44 AM   #14 (permalink)
Thanks gold, I'm going to do it.
Old 10-22-2009, 11:18 AM   #15 (permalink)
Cool..... they are all cheap enough, if it were me, I'd just buy all 3... one of each.
