Sony Stereo deck wiring - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-21-2009, 03:09 PM   #1 (permalink)
dJcHiKo
dJcHiKo's Avatar
View dJcHiKo's Photo Gallery
i got a new sony deck (cdxgt430ip)
i was wondering how im going to wire this into my corolla
i got the instructions with it and everything but do i put black to black, blue to blue red to red, yellow to yellow and all that just color to color?
or is it all different because the last corolla i had had all different colors going from the sony wire harness to the toyota wiring
I have the harness and plug in that came with the deck with all the wires on it do i just wire it color to color?
thanks
Derek
dJcHiKo is offline   Reply With Quote
Old 10-21-2009, 04:07 PM   #2 (permalink)
It's A Facial TN Member!
trife96's Avatar
View trife96's Photo Gallery
i suggest you buy a small pigtail harness from best buy or a car stereo shop It will plug into the factor harness with some bare wires on the end. Then just splice all your colors.
www.cardomain.com/ride/2950600
trife96 is offline   Reply With Quote
Old 10-21-2009, 04:37 PM   #3 (permalink)
Saloon Fanatic
View 1jzdreamer's Photo Gallery
Yep, buy the harness kit, don't hack the wiring up on the car. its 7-10 bucks well spent. Any place that sells car stereos will have it, toyota hasn't changed the plugs in years.
20v, 6 spd lsd
Boost, may you RIP.
Corners Quickly...
1jzdreamer is offline   Reply With Quote
Old 10-21-2009, 04:39 PM   #4 (permalink)
View FiZiK's Photo Gallery
Here's a pic of a wiring diagram http://www.**********s.com/supra/stereodiagram.gif
but when i upgraded my stereo i had to make my own +12 volt battery wire.
for my corolla hatch 1993.
FiZiK is offline   Reply With Quote
Old 10-21-2009, 05:05 PM   #5 (permalink)
dJcHiKo
dJcHiKo's Avatar
what exactly is a harness kit?
what would i ask for?
Derek
Old 10-21-2009, 05:36 PM   #6 (permalink)
Automotive Lighting Guru
gold94corolla's Avatar
Gameroom cash: $291352
View gold94corolla's Photo Gallery
I got my wiring kit from Walmart. It looks something like this (it is on the left, the wires from the deck are on the right)
wired in using the diagrams
gold94corolla is online now   Reply With Quote
Old 10-21-2009, 06:22 PM   #7 (permalink)
Rip The E Brake's Avatar
Gameroom cash: $112690
View Rip The E Brake's Photo Gallery
Here you are sir. This is the color combos for the entire car. Get a harness please. I hacked my wiring up like a tool.
Radio Constant 12V+ Wire: Blue/Yellow (aka Battery)
Radio Switched 12V+ Wire: Gray ( AKA Ignition)
Radio Ground Wire: Brown
Radio Illumination Wire: Green
Radio Dimmer Wire: N/A
Radio Antenna Trigger Wire: Black/Red
Radio Amp Trigger Wire: None
Front Speakers Size: 5 1/4″
Front Speakers Location: Doors
Left Front Speaker Wire (+): Pink
Left Front Speaker Wire (-): Purple
Right Front Speaker Wire (+): Light Green
Right Front Speaker Wire (-): Blue
Rear Speakers Size: 6 1/2″
Rear Speakers Location: Rear Deck
Left Rear Speaker Wire (+): Black
Left Rear Speaker Wire (-): Yellow
Right Rear Speaker Wire (+): Red
Right Rear Speaker Wire (-): White
Corolla Number TWO
OLD: Corolla 1- 96 4AFE, AE101 w/ 225k Miles orig. motor, 129k trans. - TOTALED.
NEW: Corolla 2- 96 4AFE, AE101 w/ 161k Miles on motor and trans.
Rip The E Brake is offline   Reply With Quote
Old 10-21-2009, 06:41 PM   #8 (permalink)
Yeah, the colors don't match up mostly..... I made the mistake at first lol
Old 10-21-2009, 07:25 PM   #9 (permalink)
dJcHiKo
dJcHiKo's Avatar
thanks guys, so when i go to walmart or wherever do i just ask for a wiring kit? or what
Derek
Old 10-21-2009, 07:32 PM   #10 (permalink)
go back to the audio section in automotive and look near the headunits.
Corolla Number TWO
Old 10-21-2009, 07:54 PM   #11 (permalink)
Yeah, it is hanging up on a rack! Check for your year and Toyota.
Old 10-21-2009, 08:11 PM   #12 (permalink)
dJcHiKo
dJcHiKo's Avatar
so u just pull out the factory wire and plug in the new one from walmart? and then wire it to the sony deck wiring i got?
Derek
Old 10-21-2009, 08:21 PM   #13 (permalink)
That should be how it is.
Corolla Number TWO
Old 10-21-2009, 08:32 PM   #14 (permalink)
trife96's Avatar
I guess Walmart has them. But yes, the pigtail will plug into the factory radio harness. Now your colored wires will match up perfectly to the harness that came with the radio. Color shade may vary slightly but you should still be able to figure it out. Also, I usually sit at a table and use good butt connecters, then electrical tape around each one to ensure a good connection. Definitely prevents any mistakes and having to pull the radio back out trying to figure out what wire isn't connected good.
Also this helps in case you sell the car later, you can just unplug it and plug in the old stocker
Old 10-21-2009, 08:33 PM   #15 (permalink)
I would personally use scotch locks and electrical tape if your not soldering.
Corolla Number TWO
