Transmission Problem - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-22-2009, 07:17 PM   #1 (permalink)
Bitter's Avatar
Gameroom cash: $558900
View Bitter's Photo Gallery
So my trusty rusty crusty blue geo is in the bucket.
Problem:
Trans slips in 3rd or 4th gear once the torque converter clutch locks up, feels as if it goes into neutral and will NOT drop into lower gears for a time or until i come to a complete stop and sit for a minute. I've also experienced a few long 1-2 upshifts with sluggish acceleration. fluid looks good, is about 30k old and is redline synthetic fluid, is not burnt smelling or overly dark. its still red but not brand new red. checked for trans codes, none are present and neither are any engine codes.
suggestions? i'll drop the trans pan when i can to inspect, but right now i am unable to do so.
Old 10-22-2009, 07:46 PM   #2 (permalink)
It's A Facial TN Member!
trife96's Avatar
View trife96's Photo Gallery
sorry to hear bitter. The fact that there are no codes definitely is puzzling. I would begin with checking the throttle cable and shift lever position sensor on the outside of the tranny. If those are not set right, they can cause unusual shifting points.
www.cardomain.com/ride/2950600
trife96 is offline   Reply With Quote
Old 10-22-2009, 08:08 PM   #3 (permalink)
Bitter's Avatar
yea, my throttle cable was adjusted on the tighter side of normal so it would downshift with less throttle pressure around town, i put some more slack in and it made no difference. mounts are sound, engine does not rock excessively.
this isnt a 'strange shift point' problem this is a 'falling out of gear and not going back into any gear' problem.
if it ends up being a smoked trans...as in its going to take more than a few solenoids to fix, i'll throw a 5spd in it over the winter and keep it as a spare car and get better at driving stick.
Old 10-23-2009, 02:05 PM   #4 (permalink)
Saloon Fanatic
View 1jzdreamer's Photo Gallery
So I assume its the auto on the 1.8. Is there any difference if you disengage the o/d? Slipping like that usually means the o/d unit is slipping which can be due to low fluid, low line pressure, or worn belts.
Before giving up on it, it may be worth a power flush at a trans shop, usually about 75-125 bucks. It could be as simple as a sticky valve in the trans.
If you do a 5 speed swap, locate one in the wrecking yard and i can give you the parts list as I have done it.
20v, 6 spd lsd
Boost, may you RIP.
Corners Quickly...
1jzdreamer is offline   Reply With Quote
Old 10-24-2009, 10:03 AM   #5 (permalink)
Bitter's Avatar
i work at a shop, lolz. from reading through my big red book of car (service manual) it sounds like i have a slipping underdrive clutch its active in 3rd and 4th gears ONLY, but i'm going to Ohms check the solenoids without dropping the pan sometime next week or next weekend to be sure that they're all within specs and maybe do a few tests to just confirm the issue, a stall speed and line pressure test. transmission diagnosis is my least favorite kind of diagnosis behind german electrical.
Old 11-04-2009, 09:25 PM   #6 (permalink)
Bitter's Avatar
drove it about 10 miles tonight to where its being stored with the 3 wire solenoid harness unplugged. drove without slipping in 1st, 2nd, and 3rd with no 4th (OD) or TCC lockup. i'm now wondering if it could be an electrical issue or computer issue going on.
Old 11-04-2009, 10:36 PM   #7 (permalink)
Rip The E Brake's Avatar
Gameroom cash: $112690
View Rip The E Brake's Photo Gallery
Its pretty obvious thats whats happening. Maybe you need new shift solenoids, or are they not replaceable?
Corolla Number TWO
OLD: Corolla 1- 96 4AFE, AE101 w/ 225k Miles orig. motor, 129k trans. - TOTALED.
NEW: Corolla 2- 96 4AFE, AE101 w/ 161k Miles on motor and trans.
Rip The E Brake is offline   Reply With Quote
Old 11-05-2009, 07:29 AM   #8 (permalink)
Bitter's Avatar
i bet they're replaceable, i was thinking solenoids as well...but a bad TCC solenoid should just kick me out of TCC i would think, not down into nuetral. i'll have to look at some hydraulic diagrams and see how fluid flows and whats applied/not applied with TCC is commanded by the PCM. i may just throw some solenoids at it and cross my fingers. who knows.
bottom line is, i have some diagnosis to do....but i already pretty much knew how it would drive with those wires unplugged, it really felt electrical to me.
