1.6 has a problem. Help. - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-24-2009, 02:56 PM   #1 (permalink)
The YODA
96corolla1.6's Avatar
View 96corolla1.6's Photo Gallery
gen 7 1.6 has a problem. Help.
OK, got a 96 corolla 1.6 with 130 thousand has a miss with no other code than a miss in #3. The wife said it was running fine the the check engine light came on and it started to flash and she lost power.. Has good spark, cap, rotor, wires & plugs. Misses when you put into drive or reverse. Has no power of course. Cleared the CEL and looked for broken wires, fuses and anything that would cause it, with no luck. Motor does idles ok. Some times it acts like its flooded when you floor it but, as up leave up slightly, it smooth out? Think it could be a bad injector?
OH, one more thing.. Last winter I had a really hard time getting it to start in real cold weather. Had to hold it to the floor some time to even get it to start. Acted like it was flooded?
I'm up in arms so, I ask all of you guys for some advise on this matter. I thank all you for helping me, if I forget to say thanks!
96corolla1.6 is offline   Reply With Quote
Old 10-24-2009, 04:05 PM   #2 (permalink)
Bitter's Avatar
Gameroom cash: $558900
View Bitter's Photo Gallery
check compression
how do you know the cap and rotor and plug and wires are all good? are they all new?
Old 10-24-2009, 05:27 PM   #3 (permalink)
The YODA
Originally Posted by Bitter View Post
check compression
Got them all last year.
Old 10-24-2009, 05:54 PM   #4 (permalink)
Bitter's Avatar
pull the cap and inspect it very well, a carbon track or a small crack in it will cause a misfire, also check the rotor as well as the #3 wire, try swapping the wire with #4 or #2.
Old 10-24-2009, 11:04 PM   #5 (permalink)
The YODA
Did all that all ready and no difference. did the plugs too.
Old 10-25-2009, 10:54 AM   #6 (permalink)
Bitter's Avatar
then you need to check that the injector is working and that cylinder has compression.
Old 10-25-2009, 02:26 PM   #7 (permalink)
The YODA
ok
