95 corolla charging problem
I'm working on my sister's corolla which is a hand me down from my mother, and finally from my grandmother. As I understand it, my grandmother had the alternator and battery replaced a few times during the time that she was driving it, my mother had it done once, and now it looks like it needs it again. All due to the same underlying problem (I assume) which has been plaguing this car for over 10 years. The car will run fine for a while, then it starts going through "spells" where the battery is always dead & always needs to be jump started. Sometimes even while it's running the battery will die & the car will die with it. This tells me that the alternator is dead, but I jumped the car just now and removed the pos terminal off the battery and it ran just fine. measured alternator output at a steady 14.45V. It seems as though there is something switching off the alternator once it senses that it has left the driveway. Right before it dies, all the lights on the dash flicker a few times and the engine does a little death rattle, then all is lost. Any Idea where I should look? I have the wiring diagrams and I noticed that seemingly every wire in the car goes through some unexplained "Integration relay" so I am considering that as a likely point of failure, also the computer. I don't even know where the integration relay is.
