96 corolla problem starting the engine after engine swap
I just swapped a 1.6 in a 96 Corolla and have problem starting the engine. The old and new engine are identical and are the 1.6 4AFE. I got the replacement engine without the distributor so I had to install the one from my original engine. When I tried to start it, it keeps starting and on time it starts but very, very roughtly. Could i have incorrectly installed the distributor? I've been told that there was only one way to install it(it's the distributor with the attached bolt to the casting).
I notice that there is two slots inside the engine. Can i rotate the distibutor shaft 180 deg. I tried it but seems to fit only in one position. I could have put piston #1 at TDC and make sure the rotor is at plug # 1 but I tougth it was not necessary
Is there someting special i have to do when we put a new engine, I mean about computer, ecm.
I will check if I have compression to make sure the cams vs crank are OK but this should not be an issue
Thanks!
