Car steering wheel kind of moves by itself when driving - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-24-2009, 11:27 PM   #1 (permalink)
View msrdude's Photo Gallery
gen 7 Car steering wheel kind of moves by itself when driving
I have a 96 corolla and whenever I drive, the steering wheel kind of move by itself at times, not always like 1 time every 3 times driving up to 40 mph or higher. Its like something is uneven or it is hitting some kind of bump that is causing the steering wheel to kind of move. The road is kind of uneven and has some bumps, but it should not cause the steering wheel to kind of move. My steering wheel moves very easily btw. The alignment is fine, (except the rear camber, but that is not adjustable) the rear tires are new and the fronts are almost bald but I re-balanced them, and Im guessing the rotors need to be re-surfaced but I havent replaced the brakes in years and when I did i re-surfaced the rotors.
Does anyone have any ideas of what is going on?
Cars that I own:
1996 Toyota Corolla DX
1996 Toyota Camry LE
2007 Toyota Camry SE
msrdude is offline   Reply With Quote
Old 10-24-2009, 11:51 PM   #2 (permalink)
dJcHiKo
dJcHiKo's Avatar
View dJcHiKo's Photo Gallery
just taking a guess but make sure all the air in ur tires is even
i had that same kinda problem and that was my solution
but good luck!
Derek
dJcHiKo is offline   Reply With Quote
Old 10-25-2009, 12:18 AM   #3 (permalink)
Rip The E Brake's Avatar
Gameroom cash: $112690
View Rip The E Brake's Photo Gallery
check tire pressure... if thats not it.. tie rods, tie rod ends or ball joints for sure...
Corolla Number TWO
OLD: Corolla 1- 96 4AFE, AE101 w/ 225k Miles orig. motor, 129k trans. - TOTALED.
NEW: Corolla 2- 96 4AFE, AE101 w/ 161k Miles on motor and trans.
Rip The E Brake is offline   Reply With Quote
Old 10-25-2009, 03:08 PM   #4 (permalink)
Automotive Lighting Guru
gold94corolla's Avatar
Gameroom cash: $291352
View gold94corolla's Photo Gallery
out of alignment?
gold94corolla is online now   Reply With Quote
Old 10-25-2009, 06:36 PM   #5 (permalink)
Gameroom cash: $323345
View cipher93's Photo Gallery
Minor moves could be normal depending on the road surface. If it is jerking to where you need to hold on tight to keep it steady, I would suggest checking your air pressures and then tie rod/tie rod ends as mentioned above.
cipher93 is online now   Reply With Quote
Old 10-26-2009, 10:45 PM   #6 (permalink)
Andele, andele!
speedy25's Avatar
Gameroom cash: $235545
View speedy25's Photo Gallery
Worn front end/suspension parts. Start with new tires and have a GOOD alignment shop check components carefully.
-SP
