re-install new cv axle - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-31-2009, 12:29 PM   #1 (permalink)
View onemorerep's Photo Gallery
97 camry- drivers side cv axle bad. Got the old one out with ease, but cant reinstall the new. Can't get the slip ring past the spline. Is there a trick or tool?
onemorerep is offline   Reply With Quote
Old 11-01-2009, 11:13 PM   #2 (permalink)
Andele, andele!
speedy25's Avatar
Gameroom cash: $235545
View speedy25's Photo Gallery
Slip ring???
Typically just a good shove is enough to get the circlip through and seat the axle. You may have to do it a few times before it goes in.
-SP
Old 11-04-2009, 09:52 PM   #3 (permalink)
View Jeepm@n's Photo Gallery
I used a 5lb dead blow hammer. I swapped both CV axles on my 93 in 5 hours. Your talking about seating the split ring that is on the splined shaft. I hit the far end while I held inward pressure on the shaft.
Good Luck
Jeepm@n is offline   Reply With Quote
Old 11-04-2009, 11:21 PM   #4 (permalink)
Andele, andele!
speedy25's Avatar
Your method can destroy one or both joints. Hammering is not necessary.
-SP
Good Luck
Old 11-05-2009, 06:31 AM   #5 (permalink)
MAybe if your really beating on it. Just tapping it with inward pressure is not going to destroy it.
Old 11-05-2009, 07:33 AM   #6 (permalink)
Bitter's Avatar
Gameroom cash: $558900
View Bitter's Photo Gallery
-SP
well then, better never ever hit any potholes ever because i'll tell you what, smacking a pothole at 20 is going to hit that axle alot harder than a few firm whacks from a deadblow.
Bitter is online now   Reply With Quote
Old 11-05-2009, 12:24 PM   #7 (permalink)
View stratodart's Photo Gallery
It is easier to install if you have the open end of the snap ring positioned at the bottom.
stratodart is offline   Reply With Quote
