6-Speed 4A/7AGE?? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-31-2009, 05:27 PM   #1 (permalink)
Life's better in a Toyota
Callum3's Avatar
View Callum3's Photo Gallery
6-Speed 4A/7AGE??
I been doing alot of research lately on the late 90's european corolla which have a 6-speed tranmission paired to the 4afe as an optional on the g6 and g6r versions. Unfortunately, thats about all the information i could round up, haha. Just wondering if there are any major differences between the european and american versions of the corolla 4afe. Im mainly interested in the 6 speed (more for quality of driving than performance) as well as the red dash cluster available on the g6. Has anyone out there pursued this route?
Any Information would be great!
Thanks Cal
Callum3 is offline   Reply With Quote
Old 10-31-2009, 05:34 PM   #2 (permalink)
kor-ro-ra?
midnightmach's Avatar
View midnightmach's Photo Gallery
get a mr2 6 speed, but highway driving will rape you.
RIP Corolla & Camry.
midnightmach is offline   Reply With Quote
Old 10-31-2009, 06:27 PM   #3 (permalink)
Saloon Fanatic
View 1jzdreamer's Photo Gallery
Thanks Cal
I had a c60 with my 4afe. I enjoyed it but as stated it revs around 4k-4100 rpm at 120kmh. Its a nice drive but c56 imo will do the same and you won't be rowing through the gear box in traffic. I am in 6th by 75-80km in most traffic situtations.
20v, 6 spd lsd
Boost, may you RIP.
Corners Quickly...
1jzdreamer is offline   Reply With Quote
Old 11-01-2009, 10:43 PM   #4 (permalink)
Callum3's Avatar
The 6-speed tranny would help with my accleration tho right? cuz my transmission has been rough going into 2 and 3 lately plus i've always wanted a 6-speed. Also depending if i could get a good deal at a scrap yard too
Old 11-02-2009, 03:59 PM   #5 (permalink)
Saloon Fanatic
Your going to be looking from 500 if you have a horseshoe somewhere, to a more likely 800-1000 for the 6 speed. More if you want one with the lsd. You need one off a 20v Blacktop, as you need that bellhousing to bolt the transmission to your block. The c160 from the celica/corolla xrs won't work.
I honestly would just find a c56 off a 20v as they go for 100-300 and the gearing isn't much taller then the 6 speed.
20v, 6 spd lsd
Boost, may you RIP.
Corners Quickly...
Old 11-02-2009, 11:01 PM   #6 (permalink)
Callum3's Avatar
I was under the impression the 7gen corolla had the c56 stock but i must have gotta my numbers mixed...what trany is in my car, and what cars come with the c56. Do u think i would notice the difference? Would it really be worth it? (keeping in mind the trany probs and im doing a clutch in the spring so ill have the transmission out of the car anyways) Also, what am i looking at for parts > new axles?, shift cables?, would the clutch be the same?
Old 11-05-2009, 03:49 PM   #7 (permalink)
Saloon Fanatic
Everything is the same. Bolts in. Just the gears inside are slightly different. They came on the silver and black top 20v 4age. Depending on the year of your car you have a c50 or a c52.
C160
A 6-Speed Manual Transmission for FWD cars including an optional limited slip differential. Transmission with identification code ending with 12C are LSD equipped. Code ending with 12A are non-LSD. LSD options were not available in the Wagons (ae101 corolla and ae111 carib)
Gear ratios for this transmission.
1st 2nd 3rd 4th 5th 6th Reverse Final
3.166 2.050 1.481 1.166 0.916 0.725 3.250 4.529
Applications:
* Toyota AE111 Levin/Trueno
* Toyota AE101 Corolla Wagon (1997 onwards (BZ models only)
* Toyota AE111 Carib
* Toyota AE111 Corolla GT
C56
A 5-Speed Manual Transmission for FWD cars.
1st 2nd 3rd 4th 5th Reverse Final
3.166 1.904 1.392 1.031 0.815 3.250 4.312
Applications:
* Toyota Celica
* Toyota Corolla
* Toyota Starlet Glanza V
* Toyota AE101 Levin/Trueno (Later Years only)
* Toyota MR2 Spyder (US/UK/JP) (mid-engine application)
C52
A 5-Speed Manual Transmission for FWD cars. This will fit most Toyota A series engine [1] Is used in the later mk1 (AW11) MR2.
1st 2nd 3rd 4th 5th Reverse Final Differential Gear Ratio
3.166 1.904 1.310 0.969 0.815 3.250 4.058 3.722
Applications:
* 88-91 US Toyota Corolla GTS
* Toyota Starlet GT Turbo
* Toyota MR2
* 90-92 Geo Prizm
C50
A 5-Speed Manual Transmission for FWD cars. This gearbox is known to develop a fifth gear pop out problem as it ages, primarily due to worn shifter detents caused by the driver resting their hand on the shifter. (This was supersede by C52 Transmission) Is used in the early mk1 (AW11) MR2.
3.545 1.904 1.310 0.969 0.815 3.250 3.722
20v, 6 spd lsd
Boost, may you RIP.
Corners Quickly...
Old 11-05-2009, 09:58 PM   #8 (permalink)
Callum3's Avatar
Do you think it would make a noticable difference?
Old 11-05-2009, 11:13 PM   #9 (permalink)
Rip The E Brake's Avatar
Gameroom cash: $112690
View Rip The E Brake's Photo Gallery
Unless you plan on building out a track car, no... you'll just be pissed off crusing at 4800rpm doing 65...
Corolla Number TWO
OLD: Corolla 1- 96 4AFE, AE101 w/ 225k Miles orig. motor, 129k trans. - TOTALED.
NEW: Corolla 2- 96 4AFE, AE101 w/ 161k Miles on motor and trans.
Rip The E Brake is offline   Reply With Quote
Old 11-06-2009, 03:05 PM   #10 (permalink)
Saloon Fanatic
It pulls a bit better in 2/3/4 but cruising at 5th is annoying, I can agree. Not worth the headache if your not going to do any serious driving with it.
20v, 6 spd lsd
Boost, may you RIP.
Corners Quickly...
Old 11-06-2009, 03:11 PM   #11 (permalink)
Callum3's Avatar
Thanks guys, just wanted a little more get up and go out of the old girl, but I guess i'll just have to wait a few years until i can fund an 2005 Corolla XRS built
Old 11-06-2009, 10:14 PM   #12 (permalink)
It's A Facial TN Member!
trife96's Avatar
View trife96's Photo Gallery
C160
Applications:
C56
Applications:
* Toyota Celica
* Toyota Corolla
C52
Applications:
* Toyota MR2
* 90-92 Geo Prizm
C50
If this isn't in the sticky....it should be.
www.cardomain.com/ride/2950600
trife96 is offline   Reply With Quote
