Transaxle Oil seal - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-09-2009, 03:44 PM   #1 (permalink)
ToyotaHankins
View ToyotaHankins's Photo Gallery
Transaxle Oil seal
My left cv joints have packed it in so I'm going to have to replace them. I was thinking while I had the driveaxle out I should replace the transaxle oil seal also. It's not leaking now but its happened before as soon as I disterb something it will start to leak. Has anyone else replaced this seal? Had any problems? It seems straight forward. Also is that a special seal driver for it?
Thanks
ToyotaHankins
ToyotaHankins is offline   Reply With Quote
Old 11-09-2009, 08:19 PM   #2 (permalink)
blb
View blb's Photo Gallery
I generally only replace the axle seals if they are leaking. When removing the axle, be very careful not to cut the seal with the splines on the axle, and do the same when installing the new axle. In answer to your question, yes, it is a straight forward job to replace the seals as they are just press fit. Use a seal puller or screwdriver to pry out to remove them and use a seal installer or a piece of correct diameter plastic pipe and hammer to install. I usually opt for OEM Toyota seals.
blb is offline   Reply With Quote
Old 11-10-2009, 12:05 AM   #3 (permalink)
Saloon Fanatic
View 1jzdreamer's Photo Gallery
I second this, including the oe seals from the dealer. They seem to be more resilient to abuse.
20v, 6 spd lsd
Boost, may you RIP.
Corners Quickly...
1jzdreamer is offline   Reply With Quote
Old 11-10-2009, 01:49 AM   #4 (permalink)
ToyotaHankins
yeah, thanks guys. I ordered up a seal but i refuse to pay $450 for an axleshaft from toyota so I opted to get the axelshaft from Napa for only $100.
