Spark Plug Tube Seals - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-09-2009, 07:48 PM   #1 (permalink)
blb
View blb's Photo Gallery
Do the spark plugs need to be removed in order to pull the valve cover to replace the spark plug tube seals? Car is a '95 Corolla with 7AFE engine. I'm assuming I can just pull the plug wires, remove the four bolts and pull the valve cover, but wanted to make sure the spark plugs don't need to come out too.
blb is offline   Reply With Quote
Old 11-09-2009, 08:59 PM   #2 (permalink)
It's A Facial TN Member!
trife96's Avatar
View trife96's Photo Gallery
well, you still have to remove the harness plastic cover and the harness going to the alternator, but to answer your original question, you can leave the spark plugs screwed in.
www.cardomain.com/ride/2950600
trife96 is offline   Reply With Quote
Old 11-09-2009, 09:38 PM   #3 (permalink)
Official TN Toaster
iToaster's Avatar
Gameroom cash: $348295
View iToaster's Photo Gallery
It is correct you don't need to remove the spark plugs, but you should know there's a total of 7 bolts/nuts to remove. There's the 4 obvious ones, then two holding the cover over the alternator cable (the cable itself will just slip over the valve cover), and one on the rear hook that goes over the lip of the valve cover.
1995 Corolla DX - 7A-FE - 5 Speed - 8K1
2000 Celica GT-S - Supercharged 2ZZ-GE - 6 Speed - 3P0
RIP white Corolla
iToaster is offline   Reply With Quote
Old 11-10-2009, 12:04 AM   #4 (permalink)
Saloon Fanatic
View 1jzdreamer's Photo Gallery
When removing the seals to replace them, pry gently as to not score up the aluminum surface which the seal seats against.A pry tool is optimal or put the valve cover on 2 blocks of wood and tap them out from above.
20v, 6 spd lsd
Boost, may you RIP.
Corners Quickly...
1jzdreamer is offline   Reply With Quote
Old 11-10-2009, 09:18 AM   #5 (permalink)
blb
Thanks for all of the information. I appreciate it!
