Hey guys! I just bought a new head unit (Alpine CDE-102) and had a few questions about the wiring. My car is a 1997 Corolla and the previous owner cut out the head unit plug so I am stuck with wiring it to bare wires.
1. The Black (Ground) and Yellow (12V+ power) are a bit thicker then the corollas stock ground and power wires. The ground wire from the alpine unit also has a connector on the end of it to attach it under a screw. So my question is will it be alright to just wire it up to the corollas stock ground and power wires or do I have to make new connection to power and ground?
2. My other question is in regards to the corollas stock wiring. I have found different info on which wires are for what and I am confused and unsure of which one I should follow.
As you can see with these two links:
http://www.**********s.com/supra/stereodiagram.gif
http://pad.wikihow.com/images/thumb/..._table_649.PNG
They say the ground wire is black and there is no illumination wire listed.
But according to here:
http://www.modifiedlife.com/car-ster...oyota-corolla/
The ground wire is brown and the radio illumination is green. Which one should I listen to?? I wired up a sony head unit not too long ago and I am pretty sure I wired the black ground wire to the stock corolla ground wire (which was black) and everything worked fine. That was some cheap old Sony head unit. I now have a brand new Alpine CDE-102 head unit so I don't want to just wire it up and take my chances. I would like to know for sure. Brown or Black??
3. My next question is about the illumination wire. My Alpine head unit has a wire that receives a single wen the headlights are turned on so the head unit can auto dim the display on it. Which wire is the illumination wire and is there a way I can test it? Maybe use a multimeter with the black end connected to ground and the red one connected to the suspected illumination wire and then turn the headlights on? I'm am thinking that would work. Again according to the other diagram (that says ground is brown) it says the illumination wire is Green however I don't think I trust that diagram so much because I am pretty sure the ground wire is indeed black. Also every electrical thing I have ever done has always had the ground wire as black.
