transmission help please... - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-16-2009, 01:48 PM   #1 (permalink)
View smokinj4u's Photo Gallery
i have a 95 geo prizm with a toyota 1.6L and manual transmission. well the clutch went out on it and im in the process of replacing it but i can not get the tranny to seperate from the block, i have all the bolts out and all the tranny mounts off. i am thinking that the flywheel is what is holding me back but there is no way that i can see to acess it. can anyone help me with this?
smokinj4u is offline   Reply With Quote
Old 11-16-2009, 05:30 PM   #2 (permalink)
Andele, andele!
speedy25's Avatar
Gameroom cash: $235545
View speedy25's Photo Gallery
If it wont come loose then you DONT have all the bolts out! Flywheel is only bolted to the crankshaft.
-SP
Old 11-16-2009, 11:07 PM   #3 (permalink)
It's A Facial TN Member!
trife96's Avatar
View trife96's Photo Gallery
There should be 6 bolts
www.cardomain.com/ride/2950600
trife96 is offline   Reply With Quote
Old 11-17-2009, 11:00 AM   #4 (permalink)
Before "THE WRECK"
sequoiasoon's Avatar
iTrader Score: 7 reviews
View sequoiasoon's Photo Gallery
Crazy question at this point but you did remove/disconnect the axles correct? Also does starter bolt to tranny or block?
'93 Corolla getting parted out. Will be scrap REAL SOON so TELL ME WHAT YOU WANT OR NEED!!! Pictures and videos here http://s700.photobucket.com/albums/w.../parts%20left/
sequoiasoon is offline   Reply With Quote
Old 11-19-2009, 12:13 AM   #5 (permalink)
View fast68's Photo Gallery
make sure you didnt miss one bellhousing bolt
need to have 6 out yes.
one is probsably in the back down low where you cant see, above the cv shaft output area of the transaxle diff unit output.
and on most vehicles the bolt is threaded in from pass side
unlike the other bolts
at least GM and ford ones are..
many 1987 toy truck parts, lots of parts inside and out, also have many '88 pickup parts still.. try me! pm or email me, also fastr68 on yahoo messenger anytime 24/7 signed in on there.
fast68 is offline   Reply With Quote
Old 11-19-2009, 07:12 AM   #6 (permalink)
Bitter's Avatar
Gameroom cash: $558900
View Bitter's Photo Gallery
could be corrosion around a dowel pin keeping it from separating. spray penetrating oil and smack where they join with a heavy dead blow hammer.
Bitter is online now   Reply With Quote
Old 11-19-2009, 08:21 AM   #7 (permalink)
Proud 93 Corolla owner
TI-CAVA's Avatar
View TI-CAVA's Photo Gallery
happened the same to me, last owner putted loctite in the guides
Corolla 93 1.6l 89Kw DIY mods
Intel Pentium 4 Northwood D1 @ 2.9 GHz HT,Intel D865PERL,4Gb PC3200 DDR Dual channel, ATI 9600 AGP8X 256 MB,SP0411N,ST340015A,PCTV 110i, Logitech Attack 3.
rate! NOW WITH HIGH RES PICS!! 3.2Mp
TI-CAVA is offline   Reply With Quote
Old 11-19-2009, 03:48 PM   #8 (permalink)
trife96's Avatar
loctite on the dowel pins
Starter has one bolt coming in from passenger side and one from the driver side for whatever reason
Old 11-21-2009, 12:25 PM   #9 (permalink)
Saloon Fanatic
View 1jzdreamer's Photo Gallery
Yeah, make sure the starter is out, and the bolts are all removed, then you can tap the bell housing in the area by the exhaust manifold to get it loose (on older 4af's the starter was on that side), also can pry from the bottom in the gap between the bellhousing and the stiffener brace.
20v, 6 spd lsd
Boost, may you RIP.
Corners Quickly...
1jzdreamer is offline   Reply With Quote
