Torque rating on bolts for changing clutch. (need help) - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-16-2009, 08:03 PM   #1 (permalink)
View curtains's Photo Gallery
OK my clutch in my car needs changing (97 Levin BZ-G AE111)
and I can't afford to pay for someone to do it, and I can't find a service manual for it not even if I want to buy one(you may have seen my other thread asking if anyones seen one)
So does anyone know the torque ratings for the bolts on the flywheel bellhousing and any other torque rated bolts?
if not, how much does it matter and what are the side effects of me just tighting them right up? cause i really need to change the clutch.
Thanks
curtains is offline   Reply With Quote
Old 11-16-2009, 08:10 PM   #2 (permalink)
Bitter's Avatar
Gameroom cash: $558900
View Bitter's Photo Gallery
worst case? you snap bolts off into the crankshaft and need a new crankshaft as well as a new transmission because the clutch pressure plate, flywheel, and clutch disc bounced around inside the bell housing and tore it up.
Bitter is online now   Reply With Quote
Old 11-16-2009, 09:26 PM   #3 (permalink)
Hmmm .. ok .. anyone have any advice on what i should do? .. I can't afford to take it to the mechanics the cheapest i got quoted was twice as much as DIY.
Old 11-16-2009, 10:45 PM   #4 (permalink)
It's A Facial TN Member!
trife96's Avatar
View trife96's Photo Gallery
Not sure on that model Corolla. Sorry man
AE102 Corolla manual transmission case to engine is 47 ft lbf (17mm bolt) or 34 ft lbf (14mm bolt)
www.cardomain.com/ride/2950600
trife96 is offline   Reply With Quote
Old 11-17-2009, 07:09 AM   #5 (permalink)
Bitter's Avatar
the flywheel bolts are the most critical, if thats the same 4age that cames in other cars then their torque specs should be the same. like the mr-2 maybe.
Old 11-17-2009, 11:05 AM   #6 (permalink)
Andele, andele!
speedy25's Avatar
Gameroom cash: $235545
View speedy25's Photo Gallery
With the exception of head bolts, crank and rod bolts or MAYBE flywheel bolts, fasteners have the same torque.
Thread size, NOT bolt head size
6mm 8-10 ft lbs
8mm 15
10mm 20
On many parts the actual torque isnt as important as having them torqued to the SAME VALUE, like on a manifold. Also make sure the threads are clean, and in some instances you may need to run a tap through the hole to make sure there is no corrosion to affect your torque value. Buy a tube of ARE fasteners assembly lube for important bolts, especially ones with high torque values. Oil just doesnt cut it as a thread lubricant.
-SP
Old 11-18-2009, 10:28 PM   #7 (permalink)
View smokinj4u's Photo Gallery
6mm 8-10 ft lbs
8mm 15
10mm 20
this does not apply to your flywheel... you will be fine as long as you dont over torque them... i just replaced the clutch in mine yesterday and torqued them to these specs and mine is doing fine... just make sure that you DO NOT go over the specified torque value
smokinj4u is offline   Reply With Quote
