Valve Clearance Specs - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-16-2009, 09:50 PM   #1 (permalink)
View ibedgen's Photo Gallery
I have a 97 Corolla with the 1.8L engine and 125,000 miles. The valves have never been adjusted. Can anyone tell me what the clearances need to be on the intake and exhaust sides.
The car barely passed smog on high HC and I suspect this may be part of the problem.
Thanks.
ibedgen is offline   Reply With Quote
Old 11-16-2009, 10:32 PM   #2 (permalink)
It's A Facial TN Member!
trife96's Avatar
View trife96's Photo Gallery
Sure, on a cold engine....
Intake .15-.25mm
Exhaust .25-.35mm
Check with thickness guage. record how much it's off. First check these valves.
Cylinder 1 Exhaust and Intake
Cylinder 2 Intake only
Cylinder 3 Exhaust only
Turn the crank once and align the crank pully groove with "0" on the timing belt cover.
Check only specific valves.
Cylinder 2 Exhaust only
Cylinder 3 Intake only
Cylinder 4 Exhaust and Intake
www.cardomain.com/ride/2950600
trife96 is offline   Reply With Quote
Old 11-17-2009, 09:35 AM   #3 (permalink)
Gameroom cash: $816401
View zythr's Photo Gallery
Don't you have to use shims to adjust the valves?
zythr is offline   Reply With Quote
Old 11-17-2009, 09:58 PM   #4 (permalink)
Thank you for the clearances.
Yes, you do need shims to adjust the valves. You need to know what to aim for regarding clearances and I didn't have that info. Now I can get the proper shims to meet the specs.
Old 11-18-2009, 07:18 AM   #5 (permalink)
Bitter's Avatar
Gameroom cash: $558900
View Bitter's Photo Gallery
please let us know how much they were out at 125k. i've not heard of them going very far out, people usually only re-shim if the head is off for other work.
Bitter is online now   Reply With Quote
Old 11-21-2009, 08:40 PM   #6 (permalink)
Well, I thought I would share the results of the valve clearances at 126,000 miles. All the clearances were within spec. They were all in the upper half of the tolerance range but still within specs.
I was hoping the high HC in the smog check would be related to this. Now I need to figure out what else it could be.
Old 11-22-2009, 02:00 AM   #7 (permalink)
correction: I hate Isuzus
InfInIty13X's Avatar
View InfInIty13X's Photo Gallery
Maybe the charcoal purge canister is faulty? It's just a guess. High HC would be a rich running condition no? I'm not very good with emissions. Fuel isn't burning fully, the catalyst isn't breaking the HCs down... we don't have testing in AL so I have nil experience in it but I'm still trying to flex that muscle.
'96 Geo Prizm base 280k+ miles
'91 Isuzu Impulse RS 130k+ miles (parked with bhg)
InfInIty13X is offline   Reply With Quote
Old 11-22-2009, 09:58 AM   #8 (permalink)
Bitter's Avatar
glad to hear that they were in spec!
