93 Toyota Corolla Coolant Issue - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-16-2009, 10:46 PM   #1 (permalink)
View wolfsgirl364's Photo Gallery
Coolant started leaking today pretty bad from my 93 Toyota corolla, managed to get this picture of where its leaking and was wondering if anyone could tell me what piece it is I need to get for my car to get it fixed. I tihnk its a freeze plug but I wanted to know what size I would need, if anyone could send me a link to a specific part to get for it, also are the metal or rubber freeze plugs better? If its not a freez plug please let me know what part this is and still send a link if possible.
wolfsgirl364 is offline   Reply With Quote
Old 11-16-2009, 10:51 PM   #2 (permalink)
It's A Facial TN Member!
trife96's Avatar
View trife96's Photo Gallery
freeze plug...you are correct.
www.cardomain.com/ride/2950600
trife96 is offline   Reply With Quote
Old 11-16-2009, 11:03 PM   #3 (permalink)
Ok so freez plug has been determined, but as previously stated, which is better the rubber ones or the metal ones? Also when I was looking on checkerauto.com there were many sizes of freeze plugs you could get or they were under the freeze plug section, so I wanna make sure I get the right size.
Old 11-17-2009, 05:41 PM   #4 (permalink)
Saloon Fanatic
View 1jzdreamer's Photo Gallery
If you can get one with a rubber seal at this point, one that screws in your probably better off. That edge may not be even (pitted or corroded) for another plug to seal properly, where a rubber seal will form to the surface to seal. In colder climates, we usually put a block heater in there and it goes in with the rubber gasket.
20v, 6 spd lsd
Boost, may you RIP.
Corners Quickly...
1jzdreamer is offline   Reply With Quote
Old 11-17-2009, 06:11 PM   #5 (permalink)
blb
View blb's Photo Gallery
I would not use a rubber plug as a long term fix. I would install a new brass freeze plug and if you were worried about seepage due to a rough edge on the block, I would apply a small amount of black RTV around the block surface before installing the new freeze plug.
Also, while you are at it, I would replace as many as you can get to easily, because experience says that if one has failed, the others aren't far behind.
blb is offline   Reply With Quote
