Corolla for 1k, 175k on it... fix the clutch? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-18-2009, 10:25 PM   #1 (permalink)
Registered User
View jdmbb486's Photo Gallery
x
x
jdmbb486 is offline   Reply With Quote
Old 11-21-2009, 12:27 PM   #2 (permalink)
Saloon Fanatic
View 1jzdreamer's Photo Gallery
The clutch is 140 on ebay/local shops.
Timing kit with water pump is another 125.
How you feel about doing some work is something only you know.
If the body is solid, I would without a doubt in my mind.
20v, 6 spd lsd
Boost, may you RIP.
Corners Quickly...
1jzdreamer is offline   Reply With Quote
Old 11-23-2009, 09:07 AM   #3 (permalink)
Andele, andele!
speedy25's Avatar
Gameroom cash: $235545
View speedy25's Photo Gallery
Since you have been driving with a slipping clutch your flywheel will probably have to be resurfaced OR replaced depending on how badly damaged it may be. Dont forget to replace the crank seals too while you have things apart. Rubber parts immersed in hot oil all this time tend to get rock hard and stop sealing.
-SP
Old 12-09-2009, 11:16 PM   #4 (permalink)
View fast68's Photo Gallery
yeah if there is alot of blue and black burnt areas on the plte or flywheel then you will need new
dont resurface a hydraulic clutch flywheel it will mess up the clutch and cause non functionin clutch because there is no adjustment in the hydraulic clutch to make up for missing distance/thickness of flywheel
hard to explain
i usually re-use a flywheel unless it is horribly burnt
never any issue
on the 97 cavalier we had with 200k miles on it i simply replced the leakin bad slave cylinder and slipped in a new clitch disc
works like brand new, even still, a year later now.
i dont often replce wheels or plates.
unless they are trashed horribly
always have good clutch in the vehicles after just replacin the disc
the cavalier had a nad slave cylinder so i had to get into it regardless of condition of the clutch, and it had none anymore due to always leaking out all the fluid
on yours though it sounds like the clutch disc is totally completely worn out and maybe apart
may be some bad damage to the wheel and or plate
gonna cost some bucks now to replace all the parts
may want to just tax write off donate it yeah
because after buying all the parts and then labor charges at most places the bill will be alot im sure.
if it were us at the shop here we would go probably do it for around 125 plus parts
have fun!!
many 1987 toy truck parts, lots of parts inside and out, also have many '88 pickup parts still.. try me! pm or email me, also fastr68 on yahoo messenger anytime 24/7 signed in on there.
fast68 is offline   Reply With Quote
Old 12-10-2009, 01:57 AM   #5 (permalink)
Rip The E Brake's Avatar
Gameroom cash: $112690
View Rip The E Brake's Photo Gallery
That corolla will run for another 70-100k miles.
Replace the parts and keep it moving. The longer you keep your high mileage car, the more money you'll save.
Corolla Number TWO
OLD: Corolla 1- 96 4AFE, AE101 w/ 225k Miles orig. motor, 129k trans. - TOTALED.
NEW: Corolla 2- 96 4AFE, AE101 w/ 161k Miles on motor and trans.
Rip The E Brake is offline   Reply With Quote
