Center Console Illumination - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-23-2009, 09:33 PM   #1 (permalink)
View andrewp1031's Photo Gallery
So ive been searching through the forums and figured I should just ask what the easiest fix is for the lights at the center console by the radio that show my a/c settings and everything. I tried checking fuses but didn't find any blown ones.
ALSO** I used to be able to press the brake and have the gauges light up but that also doesn't turn on unless the headlights are on.
Hope i dont sound to confusing!
andrewp1031 is offline   Reply With Quote
Old 11-23-2009, 09:52 PM   #2 (permalink)
Official TN Toaster
iToaster's Avatar
Gameroom cash: $348295
View iToaster's Photo Gallery
The pressing the brake thing, that shouldn't happen. The reason for that is a wiring short most commonly caused by melted bases on taillight bulbs. The AC controls are illuminated by a single #74 bulb (pop the trim off, then the clear diffuser and it's sitting right there) , the emergency flasher and rear defroster buttons by special neo-wedge bulbs that are almost impossible to find (remove the switch, they're on the top and bottom), and the automatic shifter by a #194 (remove trim ring, unclip shifter face, pull out bulb). That should cover everything in the center console.
1995 Corolla DX - 7A-FE - 5 Speed - 8K1
2000 Celica GT-S - Supercharged 2ZZ-GE - 6 Speed - 3P0
RIP white Corolla
iToaster is offline   Reply With Quote
Old 11-23-2009, 10:09 PM   #3 (permalink)
Rip The E Brake's Avatar
Gameroom cash: $112690
View Rip The E Brake's Photo Gallery
Check your parking and brake lights. a blown bulb often fuses the circuits together for some reason.
Corolla Number TWO
OLD: Corolla 1- 96 4AFE, AE101 w/ 225k Miles orig. motor, 129k trans. - TOTALED.
NEW: Corolla 2- 96 4AFE, AE101 w/ 161k Miles on motor and trans.
Rip The E Brake is offline   Reply With Quote
