Cannot open dorr inside, but not the common problem - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-24-2009, 10:36 AM   #1 (permalink)
View chituntang's Photo Gallery
Hello. It's my first time posting here.
OK. Let's get down to business. Took the door apart the make door handle replacement easier. However, the rod still attaches to the handle, nothing broken. It seems like the rod just does not pull the "thing" enough to unlock the door...
Anybody?
Thanks in advance
Jesse
chituntang is offline   Reply With Quote
Old 11-24-2009, 06:04 PM   #2 (permalink)
Gameroom cash: $323345
View cipher93's Photo Gallery
Did you make sure the rod snapped into the little yellow (or white) clip on the handle? If so, sounds like the rod may be bent somehow.
cipher93 is online now   Reply With Quote
Old 12-09-2009, 10:40 PM   #3 (permalink)
View fast68's Photo Gallery
usually the rod has bent or pulled straight more than is should be and needs to be bent back, adjusted to make it pull the latch lever more to release the door striker latch lever mechanism
i had to do this very thin on my 91 s-10 pickup recently
easy fix
bent to make it shorter from point A to point B and it will cause more lever pull distance action
good luck
many 1987 toy truck parts, lots of parts inside and out, also have many '88 pickup parts still.. try me! pm or email me, also fastr68 on yahoo messenger anytime 24/7 signed in on there.
fast68 is offline   Reply With Quote
