The smaller diameter fuel fill line was rusted through and I plugged that. Yes, that needs to be replaced along with the tank! I'm wondering if somehow the plugged fuel fill line is affecting vacuum to the tank and/or fuel pump pressure since it is dead ended?
Well that is the breather line to the cap. So you might want to check what happens when you open the cap, does the problem go away.
As for measuring quantity of fuel, that wont help, it would if it was a carb engine you'd work with, but since its an EFI engine, you need pressure to the injectors. Pressure is developed by restricting fuel flow via the fuel pressure regulator. Now your pump may flow freely just fine, but if its broken, it might not be able to supply the correct pressure when in the system. Get where I'm going? Only way to check for fueling on an EFI car is to either hear the pump turn on (well you know it works) or attaching a fuel pressure gauge and checking for the correct fuel pressure.
