Start delay issue - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-01-2009, 09:17 AM   #1 (permalink)
View DaveServo's Photo Gallery
Start delay issue
So, the last few week when I go out to start my '97 Corolla there's sometimes a second or so delay after I turn the key where there's nothing and then it starts right up. This morning I turned the key and got dash lights and a click the first three turns of the key and then it started right up. When it starts it's not a slow start or anything it starts right up. The strange thing is is that, after that initial start in the morning, it starts up immediately for the rest of the day but then the next morning i get the delay again. I live in MN and it has been getting colder at night so I'm not sure if that has anything to do with it. any ideas?
DaveServo is offline   Reply With Quote
Old 12-01-2009, 09:40 AM   #2 (permalink)
View hungt1999's Photo Gallery
It sounds like the contacts inside the starter motor are about to go
Typically in early stage of the problem, you will hear a click and some delays but the motor will eventually starts
The problem will be getting worse with time, in matter of weeks
The access to the starter motor is a bit akward but it is only 2 bolts. Buy the starter contact kit at the dealer for about $30. You can also find aftermaket kit for less.
hungt1999 is offline   Reply With Quote
Old 12-01-2009, 09:52 AM   #3 (permalink)
So, would it be very difficult for me to get the starter out? Also, once out, are you saying I can fix it with a starter contact kit? How difficult might that all be for a semi-noob like me? And just out of curiosity, why would it only give me a problem in the morning?
Old 12-01-2009, 10:07 AM   #4 (permalink)
Proud 93 Corolla owner
TI-CAVA's Avatar
View TI-CAVA's Photo Gallery
autozone has manuals on it's web page, it's easy but with a manual it will be easyer
Corolla 93 1.6l 89Kw DIY mods
Intel Pentium 4 Northwood D1 @ 2.9 GHz HT,Intel D865PERL,4Gb PC3200 DDR Dual channel, ATI 9600 AGP8X 256 MB,SP0411N,ST340015A,PCTV 110i, Logitech Attack 3.
rate! NOW WITH HIGH RES PICS!! 3.2Mp
TI-CAVA is offline   Reply With Quote
Old 12-01-2009, 10:08 AM   #5 (permalink)
Don't rule out other causes yet. First check if your battery and alternator are good.
In my case, at the beginning the starter clicking problem typically happens in the morning after the car has sat for a while. Eventually, it will happen anytime.
It is not that difficult to remove the starter motor, it is just a bit awkward. You have to play contortionist a bit. I removed it by accessing by laying belly flat on top of the engine bay and stretching my arm below the engine compartment to remove the 2 bolts.
Once you remove the starter motor, you can open it and change the contacts yourself, very easy.
I bought the contact repair kit at my Toyota dealer here in Canada for $30 but it should be cheaper in the USA or at Autozone etc.
The parts you need are: 28226 and 28226A
http://www.toyodiy.com/parts/p_U_199...HDKK_1904.html
Old 12-02-2009, 03:16 PM   #6 (permalink)
Thanks for all the input1 I ordered the parts from Toyota (no one in the cities had them as far as I could find) but then it dawned on me that the starter has been replaced in this car at least once. Will the parts I ordered fit the current starter? I'm reasonably sure the current one (which I think was a rebuilt) isn't a stock Toyota starter.
Old 12-02-2009, 03:19 PM   #7 (permalink)
Hmm that is tricky, I guess you will find out after you remove the starter
how much it cost the replacement contacts by the way?
Old 12-02-2009, 09:52 PM   #8 (permalink)
It's A Facial TN Member!
trife96's Avatar
View trife96's Photo Gallery
What parts did you order? A starter? Or just the solenoid?
If they are different brands, that may cause an issue. The starter solenoid may be different somehow. Something small even.
www.cardomain.com/ride/2950600
trife96 is offline   Reply With Quote
Old 12-04-2009, 12:47 AM   #9 (permalink)
I ordered parts 28226 and 28226A which are starter contacts. They were around $30 but can be returned if I don't use them.
