Location of Block Heater - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-02-2009, 11:21 PM   #1 (permalink)
View Alin99's Photo Gallery
Canada Location of Block Heater
Hi,
Where is the block heater typically located on a base model 97 Corolla? Does the base model even have a block heater as a standard feature? There is no plug that I can spot.
I have brought the car from the coast and the weather is going to turn really cold over Alberta this weekend and I'd like to not have to put the car away for the winter.
Thanks,
Alin
Alin99 is offline   Reply With Quote
Old 12-03-2009, 12:07 PM   #2 (permalink)
kor-ro-ra?
midnightmach's Avatar
View midnightmach's Photo Gallery
I'm not sure if it was standard feature. My DX Plus has it, you can tell if you have it if there is a cap for the plug attached to the grille. The wire comes out of the front of the block underneath the exhaust manifold and runs to the grille on the driver side.
RIP Corolla & Camry.
midnightmach is offline   Reply With Quote
Old 12-03-2009, 02:08 PM   #3 (permalink)
View hungt1999's Photo Gallery
I have the 1996 DX. It did not come with the block heater.
I purchased it separately a couple years later for about $100 at the dealer.
The location where it is plugged to is not easy to see, it is located towards the the back of the engine, driver's side
hungt1999 is offline   Reply With Quote
Old 12-03-2009, 09:40 PM   #4 (permalink)
It's A Facial TN Member!
trife96's Avatar
View trife96's Photo Gallery
I don't think any US versions came with them. I notice all of you are from Canada so this explains it...
www.cardomain.com/ride/2950600
trife96 is offline   Reply With Quote
Old 12-03-2009, 10:44 PM   #5 (permalink)
Andele, andele!
speedy25's Avatar
Gameroom cash: $235545
View speedy25's Photo Gallery
Hmmm, my car has it. I have the plug wrapped around the front of the grill. I dont recall where it attaches to the block, but I'll see what freeze plug its stuck into when it gets light out.
-SP
Old 12-07-2009, 05:56 AM   #6 (permalink)
Almost Hero
NTL88's Avatar
View NTL88's Photo Gallery
97 DX here. It did not come with a block heater. I'm pretty sure it was an optional accessory.
We are all everyday people.
NTL88 is offline   Reply With Quote
Old 12-08-2009, 07:52 PM   #7 (permalink)
Andele, andele!
speedy25's Avatar
I finally remembered to look in daylight hours.
It is attached to the block just under the right side of the exhaust manifold. It looks like its bolted in and not pressed in like a freeze plug. (well at least mine is!)
I have a pic, but havent seen an option to upload it with this message. PM with email addy if you wish for s copy.
-SP
Old 12-08-2009, 11:51 PM   #8 (permalink)
Almost Hero
NTL88's Avatar
toyodiy.com has diagrams of EVERYTHING
Old 12-09-2009, 01:01 AM   #9 (permalink)
Saloon Fanatic
View 1jzdreamer's Photo Gallery
Go to your partsource/canadian tire and ask them for one for it. You have to knock out a freeze plug (don't knock it into the motor, get it to spin like a coin on end and pull it out.) New one just bolts in and route the cable away from the manifold/heat.
Shouldn't be more then 40 bucks.
20v, 6 spd lsd
Boost, may you RIP.
Corners Quickly...
1jzdreamer is offline   Reply With Quote
Old 12-09-2009, 10:00 AM   #10 (permalink)
Gameroom cash: $323845
View cipher93's Photo Gallery
Is there anyway to get one of these in the US? I was checking catalogs and it does not appear to have ever been available. Winter is here and I could really use one.
cipher93 is offline   Reply With Quote
