Coldblooded Corolla (hehe) - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-06-2009, 03:15 PM   #1 (permalink)
Life's better in a Toyota
Callum3's Avatar
View Callum3's Photo Gallery
I noticed over the past few month that my 95 Corolla runs alot colder than usual. If i give the car 20min to warm up in the morning, then the needle on the temp gauge will go to 1/2 which is normal and what im use to. But if the car seems to be moving, whether it be 15kms or 400km then the needle will sit around 1/4 (seems almost like it varys slightly speed, not sure tho). Heater always blows more than adequately hot, so im wondering if its maybe a faulty sensor, no engine lights on tho. I did bleed a bit of air out of the system when the issue first occured, but that had no effect and there hasn't been anymore air entering the system. Just wondering if anyone else is experiencing this, no major issue, i'm curious more than anything.
Callum
Callum3 is offline   Reply With Quote
Old 12-06-2009, 05:04 PM   #2 (permalink)
Proud 93 Corolla owner
TI-CAVA's Avatar
View TI-CAVA's Photo Gallery
normal bias....
these cars do that
-too effective cooling system Toyota FTW!
Corolla 93 1.6l 89Kw DIY mods
Intel Pentium 4 Northwood D1 @ 2.9 GHz HT,Intel D865PERL,4Gb PC3200 DDR Dual channel, ATI 9600 AGP8X 256 MB,SP0411N,ST340015A,PCTV 110i, Logitech Attack 3.
rate! NOW WITH HIGH RES PICS!! 3.2Mp
TI-CAVA is offline   Reply With Quote
Old 12-06-2009, 05:23 PM   #3 (permalink)
Full Throttle
Kiwi-Corolla's Avatar
Gameroom cash: $953415
iTrader Score: 16 reviews
Hmm, could be a sensor. Try checking the thermostat, had a similar problem on a car I used to own and it turned out to be the cause. 20-minutes seems like a long time to warm up, takes under 5-minutes for my 5A-FE to be at normal running temp.
Old 12-06-2009, 05:24 PM   #4 (permalink)
TI-CAVA's Avatar
my thermostat is kinda new, 2 months OEM
Old 12-06-2009, 05:34 PM   #5 (permalink)
View hoanganese's Photo Gallery
Callum
It's the thermostat. I used to have the same situation as yours. I replaced my thermostat, and my car temp gauge needle sits horizontally at the middle. It stays in that position after warm-up and after driving at various speed.
hoanganese is offline   Reply With Quote
Old 12-06-2009, 06:11 PM   #6 (permalink)
Bitter's Avatar
Gameroom cash: $558900
View Bitter's Photo Gallery
i'll 2nd that motion, change thermostat.
Old 12-06-2009, 06:47 PM   #7 (permalink)
topnotch's Avatar
Gameroom cash: $110420
View topnotch's Photo Gallery
yea i 3rd the motion check the thermostat its probaly letting coolant flow in constantly.
topnotch is offline   Reply With Quote
Old 12-07-2009, 11:38 AM   #8 (permalink)
Andele, andele!
speedy25's Avatar
Gameroom cash: $235545
View speedy25's Photo Gallery
Heres a fourth.
I bet when you pull it out it will not be closed all the way.
Thermostats are made very poorly these days and failure is common., even when new.
-SP
Old 12-07-2009, 11:47 AM   #9 (permalink)
It's A Facial TN Member!
trife96's Avatar
View trife96's Photo Gallery
i agree also, if it gets stuck wide open...this also can be bad, coolant will flow too quickly, not giving it enough time to cool down as it runs thru the radiator
www.cardomain.com/ride/2950600
trife96 is offline   Reply With Quote
Old 12-07-2009, 12:35 PM   #10 (permalink)
Callum3's Avatar
Will it do harm to leave be? until the weather is a little bit better, like March/April ish...haha
Old 12-07-2009, 12:40 PM   #11 (permalink)
View MITAC's Photo Gallery
Where is the thermostat located?
I can tell you that it is not on the upper radiator hose.
MITAC is offline   Reply With Quote
Old 12-07-2009, 01:04 PM   #12 (permalink)
View dee44's Photo Gallery
You said you replaced the thermostat 2 months ago.
Are you sure the coolant mixture is correct.
Glycol does not warm up as fast as water.
If the mixture is OK I would agree, thermostat.
Make sure the rating on the thermostat is the same as the old one.
The rating will determine at what temp it opens.
You may have something stuck in the housing preventing the thermostat from closing.
Good luck.
dee44 is offline   Reply With Quote
Old 12-07-2009, 04:04 PM   #13 (permalink)
topnotch's Avatar
well where you are you will need it you wont like your engine to work below the operation temperature and in cold weather with out a thermostat will only make it worst... i have mine out becuse i live in a hot climate i dont have no snow or anything like that just rain during the rainy season and a lot of sun so for me running without one is ok but in cold climate with snow i wont risk it.
Old 12-07-2009, 06:56 PM   #14 (permalink)
Bitter's Avatar
you won't have heat and will use much more fuel. expect a cold winter with mpg in the teens.
Old 12-10-2009, 04:43 PM   #15 (permalink)
Automotive Lighting Guru
gold94corolla's Avatar
Gameroom cash: $291852
View gold94corolla's Photo Gallery
Well, mine runs colder in the winter.... the air is colder so I guess the temperature gauge doesn't go as high?
And is it really normal for it to go to half way? Mine never did, even in the summer.
It took too long for my heat to warm up, and it never really did, so I installed packing tape over the upper and lower grilles to block the air from coming in. Now, the temp gauge goes to almost half way pretty quick and I am very toasty LOL. FTW.
gold94corolla is offline   Reply With Quote
