Turbo 4AFE - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-08-2009, 03:17 PM   #1 (permalink)
View LoPrizm's Photo Gallery
Turbo 4AFE
It's a 93 Geo Prizm. Ok Im gonna start by saying that I already know...It would be smarter to just swap it...That being said I AM GOING TO BOOST IT! I already have a custom turbo exhaust manifold for the car, flanged for a nissan T28/25...I want some help in terms of some set-up ideas as well as a good way of tuning the 4AFE once it's boosted. I have the vehicle pretty much stripped under the hood in terms of getting rid of lots of "useless" stuff in my eyes. A/C delete, full exhaust-header back, intake, and really thats ALL you can do to the 4AFE lol. Any links would help and anyone who knows of a good way to tap for coolant and oil (feed and return). Please chime in if you have any helpful info. Thanks!
LoPrizm is offline   Reply With Quote
Old 12-08-2009, 04:40 PM   #2 (permalink)
topnotch's Avatar
Gameroom cash: $110420
View topnotch's Photo Gallery
well in terms of tunning you can use a greedy blue piggyback computer so that you can tune it properly and safely but you can do some reaserch on different piggyback comp and see what qualities you prefer to have
topnotch is offline   Reply With Quote
Old 12-08-2009, 08:48 PM   #3 (permalink)
Saloon Fanatic
View 1jzdreamer's Photo Gallery
I used emanage ultimate. I had a return bung welded to a spare oil pan, and had the oil feed come off of my filter relocation head.
20v, 6 spd lsd
Boost, may you RIP.
Corners Quickly...
1jzdreamer is offline   Reply With Quote
Old 12-08-2009, 09:07 PM   #4 (permalink)
Proud 93 Corolla owner
TI-CAVA's Avatar
View TI-CAVA's Photo Gallery
not to hijack the thread but this Q may help...
can the turbo be run Without a piggyback unit or management???
for example, just the turbo, boosting to a "safe" 4psi????
Corolla 93 1.6l 89Kw DIY mods
Intel Pentium 4 Northwood D1 @ 2.9 GHz HT,Intel D865PERL,4Gb PC3200 DDR Dual channel, ATI 9600 AGP8X 256 MB,SP0411N,ST340015A,PCTV 110i, Logitech Attack 3.
rate! NOW WITH HIGH RES PICS!! 3.2Mp
TI-CAVA is offline   Reply With Quote
Old 12-09-2009, 12:57 AM   #5 (permalink)
Saloon Fanatic
The map sensor will send a out of range signal to the ecu once it hits positive pressure and the ecu will freak out. If you were to get a map clamp (won't let the voltage exceed a set amount) and get a rising rate fmu (fuel management unit) you may not pop it immediately but will eventually as the stock injectors are puny. You need something for fuel management, you could use a additional injector controller in combination with the rising rate fmu and that may work. But imo its hokey and half assing it, and you will have spent a fair amount of cash to only end up wishing you bought an emanage or something else. With the emanage ultimate, you can install different injectors and tell the emanage what size the old ones were, what the new ones are, and it does the math for you.
20v, 6 spd lsd
Boost, may you RIP.
Corners Quickly...
Old 12-09-2009, 08:53 AM   #6 (permalink)
topnotch's Avatar
that is correct plus its better safe than sorry not to go half way about the turbo set up. ive seen many guys in my country do poor turbo set ups without Emanagment and had to spend more money because of a blown hose or blown head gasket or worst conditions. so i would advise you get the right stuff, i know it would take time and money but its better in the long run.
