wont work - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-15-2009, 08:47 AM   #1 (permalink)
dJcHiKo
dJcHiKo's Avatar
View dJcHiKo's Photo Gallery
wont work
so i have my sony headunit, and for some reason it wont work in my car
i have a 1994 toyota corolla
i used this diagram to wire it..
http://www.**********s.com/supra/stereodiagram.gif
and it goes along with my sony wiring manual too.. its exactly the same as it says.. but the illumination wont turn on and i cant get any sound out of it.. it just doesnt work at all..
the cig/radio fuse is not blown..
the head units fuse is not blown..
i tried the sony headunit in my friends car (we just unplugged his sony and plugged mine in) and it worked fine in his car
someone please help! this sucks
thanks
Derek
dJcHiKo is offline   Reply With Quote
Old 12-15-2009, 02:49 PM   #2 (permalink)
Rip The E Brake's Avatar
Gameroom cash: $112690
View Rip The E Brake's Photo Gallery
Check the 20amp under the hood.
I blew quite a few of those... I also had my radio ground wire go bad, so I had to jump it down at the cig.
Corolla Number TWO
OLD: Corolla 1- 96 4AFE, AE101 w/ 225k Miles orig. motor, 129k trans. - TOTALED.
NEW: Corolla 2- 96 4AFE, AE101 w/ 161k Miles on motor and trans.
Rip The E Brake is offline   Reply With Quote
Old 12-15-2009, 04:12 PM   #3 (permalink)
dJcHiKo
dJcHiKo's Avatar
hey thanks ill check it out,
whats the fuse called on the fuse cover?
Derek
Old 12-15-2009, 04:12 PM   #4 (permalink)
I forget, if your standing alone the driver side fender, looking into the fuse box, it is the upper left orange 20 amp fuse.
Corolla Number TWO
Old 12-15-2009, 04:15 PM   #5 (permalink)
dJcHiKo
dJcHiKo's Avatar
alright im gonna run out and check quick brb
Derek
Old 12-15-2009, 04:30 PM   #6 (permalink)
dJcHiKo
dJcHiKo's Avatar
brrrrrrrrrrr!!!!!!! its freeeeeeeezing outside,
but guess what! it worked!
thanks a lot man, the fuse is labeled as dome, and my dome light wasnt working either now it is.. lol i was looking at the fuse cover the other day but didnt see anything about radio so just left it,
thanks a lot though man props!
Derek
Old 12-15-2009, 04:38 PM   #7 (permalink)
Your suppose to remove the negative battery cable before doing any radio wiring or any electrical wiring for that matter...
Corolla Number TWO
Old 12-15-2009, 04:58 PM   #8 (permalink)
dJcHiKo
dJcHiKo's Avatar
yes yes i know lol i did,
thanks a lot though
k rip i got another question for you :P
k so i got the headunit working, works good now, it has 3 different modes.. tuner (radio) aux (auxilary) and ipod (theres an attached cord that i can plug an ipod directly into)
i hooked up my amp... everything works fine on tuner.. but when i switch it to aux or ipod my amp shuts off.. whys that? im pretty confused
Derek
Old 12-15-2009, 09:23 PM   #9 (permalink)
thanks a lot though
Turn the volume down on what ever input device your plugging in, more then likely your overloading it.
Corolla Number TWO
Old 12-15-2009, 09:36 PM   #10 (permalink)
Before "THE WRECK"
sequoiasoon's Avatar
iTrader Score: 7 reviews
View sequoiasoon's Photo Gallery
My guess is that you used the power antenna lead as the amp turn on. Many radios turn off the power antenna lead when you switch to any other input source. You will need to verify that and find a different turn on lead source.
'93 Corolla getting parted out. Will be scrap REAL SOON so TELL ME WHAT YOU WANT OR NEED!!! Pictures and videos here http://s700.photobucket.com/albums/w.../parts%20left/
sequoiasoon is offline   Reply With Quote
Old 12-15-2009, 09:37 PM   #11 (permalink)
This...
Unless your car doesn't have a power antenna.
Does it power OFF or go into power protect? Remember, you need to run the amp to the 12v hot on the aftermarket harness, most often the BLUE wire.
Corolla Number TWO
Old 12-15-2009, 11:04 PM   #12 (permalink)
dJcHiKo
dJcHiKo's Avatar
i used the blue wire which im pretty sure is the amp, on the aftermarket sony wiring,
and there is also a blue wire with white stripe on it which i think is antenna
Derek
Old 12-16-2009, 04:36 AM   #13 (permalink)
Blue wire with white strip is probably it., but IDK.
Corolla Number TWO
Old 12-16-2009, 06:41 AM   #14 (permalink)
Before "THE WRECK"
This...
I didn't mention anything of the car as it doesn't matter. You need to brush up on skills and experience. Not sure which model he has but here is a Sony http://www.docs.sony.com/release/CDX...stall_conn.pdf. You need to use the blue with white stripe which is the AMP remote lead.
The plain blue supplies power to the antenna lead ONLY when the radio is in in tuner mode as stated in the instructions. Does not matter what vehicle it's in or if it has a power antenna. Also MANY new cars including Toyota and Scion do not have a power antenna BUT they do have an antenna booster amp that needs power or your reception is garbage.
Old 12-16-2009, 10:10 AM   #15 (permalink)
dJcHiKo
dJcHiKo's Avatar
alright thanks sequoiasoon, ill switch it to the blue with white tonight when i get home from school
Derek
