new alternator still not charging - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-19-2009, 09:53 PM   #1 (permalink)
View RunnoverU's Photo Gallery
Hello all. I am having some issues with the alternator on my 94 corolla. The battery light came on and the car died. I could charge the battery and still drive the car. I had the battery tested and it is fine. I put a new alternator in and it was still not charging and the battery light is still on. I checked the fuse under the hood and it is good. Is there another fuse that can cause the alternator not to charge? Also when removing the alternator I pulled out the yellow wire from the engine block according to this post
What's the sensor right underneath the alternator that plugs
it is just an oil pressure sensor and should not affect the charging system. Please help me out. Thank you.
RunnoverU is offline   Reply With Quote
Old 12-20-2009, 01:10 AM   #2 (permalink)
Official TN Toaster
iToaster's Avatar
Gameroom cash: $348795
View iToaster's Photo Gallery
That would seem to indicate that there is wiring amiss somewhere, which is usually a pain to locate. Check to see that all the wires are properly connected and undamaged.
1995 Corolla DX - 7A-FE - 5 Speed - 8K1
2000 Celica GT-S - Supercharged 2ZZ-GE - 6 Speed - 3P0
RIP white Corolla
iToaster is online now   Reply With Quote
Old 12-20-2009, 04:55 PM   #3 (permalink)
topnotch's Avatar
Gameroom cash: $110420
View topnotch's Photo Gallery
and if that dosnt work then have a dianogistic check..... was the alternater that you taken out faulty?
topnotch is offline   Reply With Quote
Old 12-21-2009, 08:23 AM   #4 (permalink)
Andele, andele!
speedy25's Avatar
Gameroom cash: $235545
View speedy25's Photo Gallery
the problems your having are not easily fixed in a forum like this. If you have checked all the easy things like looses connectors you need to find someone good in electrical work.
-SP
Old 12-21-2009, 11:35 AM   #5 (permalink)
I have figured it out. The new alternator I bought was just bad off the shelf. All of the wiring was good and the fuses were fine too. I check for power at the grey connector from the car to the alternator and there was power there, meaning that there was no short along the way. Bought a new alternator and it works fine. O'reilly's was a big help the printed off a wiring diagram to help me out.
Old 12-22-2009, 08:16 PM   #6 (permalink)
Andele, andele!
speedy25's Avatar
Good job! Nice to hear the guys behind the counter were helpful.
-SP
