the 7afe and 4afe share an identical head. The longer stroke in the 7afe makes the pistons a different size as the pin sits higher up in the piston if I recall correctly. I thought about using a redtop (ae92gts) bottom end with the 4afe head at one time and figured it should be a bolt over. You would gain oil squirters, the stronger rods, the higher 4age compression, and the larger bearing journals but at the end of the day decided it wasn't worth the effort for the flow of the 4afe head. I ended up turboing the 4afe and then when desiring a na motor, I rebuilt and installed a 20v instead.
Bill Sherwood disagrees though and claims the 4afe head is a great one, so im at a toss up on it.
20v, 6 spd lsd
Boost, may you RIP.
Corners Quickly...
