help! flat spot in low rpms - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-24-2009, 04:40 PM   #1 (permalink)
topnotch's Avatar
Gameroom cash: $110420
View topnotch's Photo Gallery
hi guys.. so here goes the sernerio ive recently had my engine overhauled and sence ive gotten back the car it dosnt sound rite, when moving from a stop as i press the accelerator thers a flat spot just before 1000rpm's after 1000rpm's the car sound fine, while goin through 1000rpm's from a stop it sounds like its trying to catch itself like a clogged fuel injector or clogged trottle body but the thing is i took down the trottle body the plenium and took out the injectors to have everything cleaned put it all together again and i still have that flat spot,later after examining the whole engine bay for unconnected hoses i found one that the mechanic didnt put in, this hose led from the trottle body and connects to another double pipe which one goes to the fuel regulator,so i disconnected the battery pumped the brake a few times (not sure what that does) to reset the ecu, unfortunatly i still have the flat spot altho its not as bad as before... so ther it is am really stumped on this one i thinking of an ecu fault or problem, any ideas are soooo welcome thanks
topnotch is offline   Reply With Quote
Old 12-24-2009, 05:08 PM   #2 (permalink)
Proud 93 Corolla owner
TI-CAVA's Avatar
View TI-CAVA's Photo Gallery
below 1000RPM i don't think the engine can keep up... i mean IDLE is 900-1000RPM... AC on idle is 1200RPM....
Corolla 93 1.6l 89Kw DIY mods
Intel Pentium 4 Northwood D1 @ 2.9 GHz HT,Intel D865PERL,4Gb PC3200 DDR Dual channel, ATI 9600 AGP8X 256 MB,SP0411N,ST340015A,PCTV 110i, Logitech Attack 3.
rate! NOW WITH HIGH RES PICS!! 3.2Mp
TI-CAVA is offline   Reply With Quote
Old 12-24-2009, 05:13 PM   #3 (permalink)
topnotch's Avatar
well rite now it idle's around 1000 rpm's in park but when i put it in drive it drops below 1000rpm lets say around 800rpm dont know why it drops that low but when i accelerate it soundslike it misses a beat in rpm and stutters tikk it passes 1000rpm.
Old 12-24-2009, 05:15 PM   #4 (permalink)
topnotch's Avatar
its even worst with the ac on you can hear the engine stutter at intervals even in park
Old 12-24-2009, 07:14 PM   #5 (permalink)
topnotch's Avatar
ok update guys... i did some reaserch on possible reasons for the flat spot and irratic idling at low rpm, and found out that the TROTTLE POSITION SENSOR can be one of the causes, so i went out to check it out and set it and now its idiling at a perfect 1000rpm in park and when put in drive it drops to 900rpm but i have to test drive it tomor to see how it responds altho am still getting that hiccup in the idiling at periods sound like possible missfire? if so what causes that ? any response and help is greatly appreciated.
Old 12-24-2009, 07:32 PM   #6 (permalink)
Automotive Lighting Guru
gold94corolla's Avatar
Gameroom cash: $291852
View gold94corolla's Photo Gallery
Did they reset the ECU? If so, it takes a while for it to relearn it's settings, and until it does, it will be hesitant like you say. ?
gold94corolla is offline   Reply With Quote
Old 12-24-2009, 07:40 PM   #7 (permalink)
topnotch's Avatar
hmmm ok i'll gave it sometime to relearn its settings then but as for the slight jerking when the engine sounds like its miss firing while in drive is also contribute to the ecu relearning or is it a distributor or spark plug issue?
Old 12-24-2009, 11:55 PM   #8 (permalink)
Sometimes these problems just iron themselves out after a while....
Old 12-25-2009, 05:54 AM   #9 (permalink)
topnotch's Avatar
yea i guess so... it has me drinking gas like a camel tho lol but am just goin to look over the distributor and spark plugs and take it for a country drive later on today, but at least sence i reset the TPS she idle alot better
Old 12-25-2009, 02:26 PM   #10 (permalink)
Drinking gas like a camel..... so you are getting 100 MPG?? LOL.
Old 12-25-2009, 04:07 PM   #11 (permalink)
topnotch's Avatar
lol
