Brake Master Cylinder aftermarket recommendations - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-28-2009, 10:02 PM   #1 (permalink)
View Superchrd's Photo Gallery
I am looking to buy a master cylinder for my '96 corolla dx (1.8l)
I bought one from Autozone (Fenco) I think that didn't even solve
my soft pedal problem.
So I decided to get one from rockauto.com
There are some brands like:
A-1 CARDONE
CARDONE SELECT
DORMAN
BECK/ARNLEY
WAGNER
RAYBESTOS
ACDELCO
Conventional wisdom says to buy the second cheapest (in this case DORMAN), but let me try polling some of you guys in the forum.
What are you experiences with brake master cylinders besides OEM?
Thanks
Superchrd is offline   Reply With Quote
Old 12-28-2009, 10:22 PM   #2 (permalink)
Official TN Toaster
iToaster's Avatar
Gameroom cash: $348795
View iToaster's Photo Gallery
The only one of those brands I've ever heard of is AC Delco, so I'd go with them.
1995 Corolla DX - 7A-FE - 5 Speed - 8K1
2000 Celica GT-S - Supercharged 2ZZ-GE - 6 Speed - 3P0
RIP white Corolla
iToaster is online now   Reply With Quote
Old 12-28-2009, 11:29 PM   #3 (permalink)
Rip The E Brake's Avatar
Gameroom cash: $112690
View Rip The E Brake's Photo Gallery
How do you know that the BMC is the culprit? Did you check all your lines for pinholes? Check all the steel lines too?
Corolla Number TWO
OLD: Corolla 1- 96 4AFE, AE101 w/ 225k Miles orig. motor, 129k trans. - TOTALED.
NEW: Corolla 2- 96 4AFE, AE101 w/ 161k Miles on motor and trans.
Rip The E Brake is offline   Reply With Quote
Old 12-29-2009, 08:50 AM   #4 (permalink)
Andele, andele!
speedy25's Avatar
Gameroom cash: $235545
View speedy25's Photo Gallery
My experience with autozone is ALL BAD when it comes to brake master cylinders. Biggest problem is they leak. Next they just dont work out of the box.
I've had no problems with other brands.
-SP
Old 12-29-2009, 11:49 PM   #5 (permalink)
Yes, and yes. I had my mechanic whom I go to do the work that is too hard for me to do, double check.
some times it will stiffen up a bit, but not good enough, then loosen a lot.
Now after the BMC change it stiffens a bit more, and loosens less. Still no good.
used 1.5 big bottles of fluid to take the air out of the system.
Old 12-30-2009, 03:18 PM   #6 (permalink)
View a3on75's Photo Gallery
Sounds to me like your vacuum booster may actually be the culprit here. the pedal will be slightly soft it is just the way they are. The booster on these cars are actually quite large for their size. The reason the pedal is going to be soft is because the vacuum on the front side of the booster has a slight pull on the pedal to help you apply greater force to the brake system. To test your vacuum booster shut your car off and pump the pedal around ten times. Make sure to pump slowly as to not aerate your brake system. After pumping it the pedal should get firm. If the pedal does not get firm after pumping it there is most likely air in the lines or a leak. after the pumping firmly press the brake pedal down and then start the car. You should feel the pedal drop some, this is the vacuum booster operating as it should, if it doesn't the booster is bad. Any more questions feel free to PM me. Thanks
A3on75
a3on75 is offline   Reply With Quote
Old 12-30-2009, 05:06 PM   #7 (permalink)
Greasewrench's Avatar
View Greasewrench's Photo Gallery
Cardone is a good brand, either A1 cardone or the new select cardone are good ones. the select brand comes with a new reservoir too, i wish i had bought that one but i went with the reman cardone A1. BTW the bleeder kits that they come with are really horrible man, theyre made of cheap plastic. u gotta screw them into the MC ports and they easily strip out since u r trying to screw plastic into metal. u can buy professional kits made of brass or aluminum fittings for about $80 that work real good. i got one from napa for $58. it is on the expensive side to buy the pro kit but if u don't bench bleed the thing right u can forget about driving the car anywhere
Greasewrench is offline   Reply With Quote
Old 01-01-2010, 11:18 AM   #8 (permalink)
View Jimp's Photo Gallery
Check the calipers
I have had the same problem on two different corollas. In both cases it turn out to be a caliper (the pins were frozen). In the first case, I was convinced it was the master cylinder and replaced it first with an after market and then with a Toyota ($$).
Jimp is offline   Reply With Quote
