Hate to bump an old thread, but I can answer this and have a couple related questions.
The fitting is 16mm. Since a lot of wrench sets skip the even numbers after 14mm, a 5/8" wrench works just fine (5/8" = 16.1mm or so). The leak could be from the o-ring on the old fitting or it could be a seal in the rack itself. Most parts stores sell a steering rack seal kit, so you may be able to repair it yourself.
Now... does anyone know what size Torx driver I need to remove the upper fitting (by the pump)? T60? It looks like a large hex-head socket would work as well, but again I don't know what size. I could go buy a bunch of metric sockets and then return the ones that were the wrong size, but that would be an expensive PITA.
I have a spare pressure hose, but it's missing the o-ring. I must have dropped it somewhere. If Autozone can't get me an o-ring (the hose is Duralast), I'm going to go to NAPA to find a replacement, but I want to make sure I'm buying the correct material. Is the o-ring a basic nitrile o-ring, or is it a special material?
