Need help no current going to the spark plug - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-02-2010, 09:37 PM   #1 (permalink)
View Relic23's Photo Gallery
I have a 94 corolla. Turned off and won't start anymore. Gas pump is working fine. The battery has full charge. So I then check and no current going to the spark plug. I got a new distributor complex from the junk yard and still no current to the spark plug. Can it be that the new complex I got doesn't work also or what else can it be thanks.
Relic23 is offline   Reply With Quote
Old 01-03-2010, 02:18 AM   #2 (permalink)
Official TN Toaster
iToaster's Avatar
Gameroom cash: $348795
View iToaster's Photo Gallery
This may seem silly, but did you check the spark plug wires?
1995 Corolla DX - 7A-FE - 5 Speed - 8K1
2000 Celica GT-S - Supercharged 2ZZ-GE - 6 Speed - 3P0
RIP white Corolla
iToaster is online now   Reply With Quote
Old 01-03-2010, 10:18 AM   #3 (permalink)
ShawnM's Avatar
View ShawnM's Photo Gallery
The most typical failures for those is the coil. If I remember right the coil in that one is mounted inside the distributor (under the cap). The problem with junkyard parts is you dont really know what your getting. It could have come out of a car that had more wear and tear on it than yours. They may swap it out with another one for you if you want to try that. Its either that of take it somewhere to at least have it diagnosed.
--Shawn
03 Camry LE
97 Lincoln MarkVIII LSC
67 Mustang
ShawnM is offline   Reply With Quote
