amp wiring grounds - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-05-2010, 10:52 PM   #1 (permalink)
dJcHiKo
dJcHiKo's Avatar
View dJcHiKo's Photo Gallery
amp wiring grounds
i have an 8 gauge power wire (battery to amp), it doesnt have a wire going from the fuse to the battery i was wondering if i could cut part of it off the other end and put it on there and put a circly ground thing on it to put on the battery?
also i dont have an amp to ground wire, can i again, cut another peice off the power wire and use that as a ground?
thanks guys let me know!
Derek
dJcHiKo is offline   Reply With Quote
Old 01-05-2010, 11:12 PM   #2 (permalink)
Full Throttle
Kiwi-Corolla's Avatar
Gameroom cash: $953415
iTrader Score: 16 reviews
Yep, that's exactly how you're meant to do it. Just strip each end of the wire and you'll be good to go.
The general rule is that the ground wire should be the same size (or larger) as the power cable. So the 8 gauge power wire will work fine as a ground.
Old 01-05-2010, 11:13 PM   #3 (permalink)
dJcHiKo
dJcHiKo's Avatar
kk thanks man i just wasn't entirely sure
Derek
Old 01-07-2010, 11:23 AM   #4 (permalink)
View gameguru1360's Photo Gallery
yeah you should definitely fuse no more than 12" from the battery. Most amp kits use an 80a AGU fuse. I personally would use an ANL fuse in an ANL fuse holder. The ANL fuses can take more power as the AGU tend to pop easily but since your power and ground wire is only 8ga, an AGU fuse and fuse holder should be ok.
Totaled 1996 Corolla DX
2009 Nissan Altima 2.5S with Takeda SRI, stock dual exhausts, mesh grille
LED bulbs for dome/map/turn signal/tail light/3rd brake light/back up bulbs
gameguru1360 is offline   Reply With Quote
Old 01-07-2010, 04:21 PM   #5 (permalink)
dJcHiKo
dJcHiKo's Avatar
yea i have 2 other 4 gauge wires with fuses and whatnot but im just powering a little amp for speakers right now so thats all i need
thanks though!
Derek
