Starts but idles badly. - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-06-2010, 11:43 AM   #1 (permalink)
View groovy's Photo Gallery
1997 Corolla
I was driving home the other day and my engine started making a bad tapping sound, When i got it home it had changed into more of a knock and the mil was on and the code was a cyl. 4 misfire. Any ideas on what it could be?
groovy is offline   Reply With Quote
Old 01-06-2010, 07:06 PM   #2 (permalink)
Gameroom cash: $323845
View cipher93's Photo Gallery
Check all the basic stuff first: sparkplugs and gaps, plug wires, distributor cap, distributor rotor.
cipher93 is offline   Reply With Quote
Old 01-07-2010, 12:01 PM   #3 (permalink)
Andele, andele!
speedy25's Avatar
Gameroom cash: $235545
View speedy25's Photo Gallery
By your audio description, it sounds like you are losing a rod. Unless you find something obvious, you'll be dropping the pan for an inspection.
Hows your oil consumption/level been?
-SP
Old 01-08-2010, 10:15 AM   #4 (permalink)
Its always had an oil problem but it hasn't changed lately, But your probably right it has almost 400k i imagine its due for a rebuild.
Old 01-08-2010, 11:48 PM   #5 (permalink)
topnotch's Avatar
Gameroom cash: $110420
View topnotch's Photo Gallery
yea its probaly that time for sure i recently got mine overhauled so if its goin to be that change eveyrthing
topnotch is offline   Reply With Quote
Old 01-10-2010, 10:19 PM   #6 (permalink)
If it is a rod, ring, or something of that nature you're better off just getting an engine from a junker. That said if you run a compression test and nothing is wrong, I wouldn't touch it.
Old 01-11-2010, 03:28 PM   #7 (permalink)
View mvftw's Photo Gallery
As mentioned above, do the basic stuff & check for a vacuum leak (broken hose)...
mvftw is offline   Reply With Quote
