95 Corolla, imterminting miss - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-07-2010, 09:41 PM   #1 (permalink)
View 96corollaChicago's Photo Gallery
Question 95 Corolla, imterminting miss
I have a 1995 Corolla w/1.6L. recently, sometimes after stopping the car sounds like its going to die. and it has died a couple times, then it starts back up, then couple more block itll do it again, but then again it will do it and not die, just a real real low idle like you have to give it gas to keep it running, i changed the air filter, checked for a broken vacum lines, and i also changed fuel filter.
any suggestions???
96corollaChicago is offline   Reply With Quote
Old 01-08-2010, 01:27 PM   #2 (permalink)
It's A Facial TN Member!
trife96's Avatar
View trife96's Photo Gallery
vsv and/or intake is dirty. This is more a prevealant problem when it gets cold. I just recently posted on a thread where someone else is having similar issues.
www.cardomain.com/ride/2950600
trife96 is offline   Reply With Quote
Old 01-08-2010, 08:01 PM   #3 (permalink)
i hate to sound stupid or anything but what is "vsv" i changed airfilter (clean out box) and fuel filter, still did it just not died. low idle, rough idle. im at a lost...
Old 01-10-2010, 07:10 PM   #4 (permalink)
trife96's Avatar
VSV is part of your EGR setup. It sounds like it's probably dirty. It is basically a valve that allows exhaust gas to recirculate back into the intake. Upon decelleration, the valve is supposed to close. If it sticks open, it's still allowing exhaust gas to pass thru it, causing the RPM's to drop enough to cause the rough idle and possibly stall.
