To change Tranny fluid or not ? ? ? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-14-2010, 01:57 PM   #1 (permalink)
View Brad1's Photo Gallery
I have a '94 Corolla DX that I purchased 4.5 yrs ago. I bought the car from a dealership so I don't have access to the maintenance records. The car had 105k miles on it at the time. It now has 138k miles on it. I have never changed the tranny fluid since I bought the car. I'm debating on whether or not I should. I am aware that if you change tranny fluid on a car that hasn't had the fluid changed for quite a while you can actually cause the tranny to start slipping. I had actually had that happen to me years ago. Had a mid-80s Chrysler that was long over due for a tranny fluid change. After I changed the fluid, it start slipping. I know older Fords were notorious for that as well. But does the same apply to my Corolla?
Brad1 is offline   Reply With Quote
Old 01-14-2010, 02:33 PM   #2 (permalink)
Gameroom cash: $252510
iTrader Score: 6 reviews
View BDSL's Photo Gallery
Maybe these slipping were caused by improper fluids.
I have change tranny fluids on both auto and manual transmissions all the time. No problem here. Stick with what your owner's manual specifies (i.e. ATF Dexron)
On my mom's 97 corolla, it specifies that the tranny fluid to be changed every 24,000 km. Thats roughly 15,000 miles!!!
BDSL is offline   Reply With Quote
Old 01-14-2010, 02:50 PM   #3 (permalink)
This is what I was referring to as my concern:
Transmission failure. Very sad.
Old 01-14-2010, 03:17 PM   #4 (permalink)
Greasewrench's Avatar
View Greasewrench's Photo Gallery
the main question u need to answer before u start to worry about possible trans failures is what is the condition of the fluid NOW? is it still reddish in color? is the fluid clean looking with no metal shavings? if your answer is yes to both of these then go ahead with the change. u should change the filter, fluid and pan gasket and clean the magnets to get the job done right. synthtetic ATF is really the way to go, but its up to u. also dexron VI supercedes all previous ones so buy that if u can versus just getting regular dexron III which is kinda obsolete now. if u r not having any issues with the trans then i say go for it
Greasewrench is offline   Reply With Quote
Old 01-14-2010, 03:45 PM   #5 (permalink)
It's A Facial TN Member!
trife96's Avatar
View trife96's Photo Gallery
^ correct...in fact, I changed my fluid and removed the trans pan on both of my Corollas (94 and 97 with `1.8 3 speed w/OD). One with unknown mileage and the other with aprox. 100K. I have had no problems with either one
www.cardomain.com/ride/2950600
trife96 is offline   Reply With Quote
Old 01-14-2010, 03:45 PM   #6 (permalink)
Not having any issues with the tranny now. The fluid is a little darker than the bright red color of new tranny fluid. No metal shavings however.
But the real question is, will changing it now potentially cause it to start slipping?
Old 01-14-2010, 03:47 PM   #7 (permalink)
trife96's Avatar
Possibility of slippage is very slim. I doubt you will have any problems.
Old 01-14-2010, 03:49 PM   #8 (permalink)
How long (how many miles) between changing the fluid as you mentioned above, and the previous fluid change?
I've heard the problem occurs when it is too long between fluid changes on a high mileage tranny.
Old 01-14-2010, 04:12 PM   #9 (permalink)
View toyomoho's Photo Gallery
If the fluid is just a little darker then bright red change it.
The fluid color people are talking about in posts is jet black.
Old 01-14-2010, 04:39 PM   #10 (permalink)
Rip The E Brake's Avatar
Gameroom cash: $112690
View Rip The E Brake's Photo Gallery
DO NOT CHANGE THAT FLUID. (if it isn't Red anymore. If the fluid color is bright red.... feel free, if it is anything but that, DO NOT TOUCH)
Thank you.
Corolla Number TWO
OLD: Corolla 1- 96 4AFE, AE101 w/ 225k Miles orig. motor, 129k trans. - TOTALED.
NEW: Corolla 2- 96 4AFE, AE101 w/ 161k Miles on motor and trans.
Rip The E Brake is offline   Reply With Quote
Old 01-14-2010, 09:10 PM   #11 (permalink)
trife96's Avatar
Thank you.
Why change it if it is bright red
Old 01-15-2010, 06:52 AM   #12 (permalink)
Thank you.
It is dark red. But not the bright red color of new ATF.
Like I mentioned in my original post, I had (on a previous car) experienced slippage immediately after changing the fluid on a car that had gone an extended period of time without a fluid change. That a Chrysler however. My main reason for this thread was to find out if the same holds true with Toyotas.
