yea, the head is pretty critical. And for $500 is a good bit. But for that much, I would have expected them to go by the book on that one. Check springs, valves, cam lobes, bearings. Then reassembly, intake and exhaust valve seals are different. And like said above. Torque specs are really important when it comes to certain parts. The head, intake and exhaust manifolds, etc. I hope they rebuilt it right. I hope that helps some. I would check the torque on that head though. Pull the valve cover. At this point, at least monitor it but if you keep noticing it get worse, I would investigate further
also wanted to mention. You said you had the cams in and out a few times. The cams need to be handled carefully. Hopefully you didn't mess them up by handling them alot. Did you have them checked???
Reason: also
