Probably the bulbs are burnt out on the cluster. Someone here can tell you what they are exactly, but you'll need 4. To remove the gauge cluster, the black bezel is held in by two screw up top. Once you remove those pull gently on it to get it to pop out. Be sure to tilt your wheel down if it was a tilt wheel. If not, be very careful and try to pull it out at an angle. Next, there are four screw in other corner that need removed. Be very careful and use a magnetic screw driver so you don't drop those screws to no man's land.
After that, very slowly pull it out, and using a precision flat head screw driver, depress the little white clips on each of the three wire bundles connected to the cluster and wiggle it a little at the same time to disengage them. There are two on each side. After that, flip it over. The four big bulbs are the ones you want. They're easy to get online and I believe you can get them in different colors too.
