Best way to bleed air from Heater Core? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-22-2010, 09:29 AM   #1 (permalink)
View sometoyotaguy's Photo Gallery
My wifes 95 corolla has an all but useless heater. Both hoses seem hot, and the valve seems to operate properly. The temp gage registers about halfway once it's warmed up.
I changed the thermostat awhile back, but that didn't seem to help. Would air trapped in the core cause that issue? The air coming out is only about 90 degrees. I looked around in the old threads, but didn't find much of anything. I do have a new water pump, so I know that's not the issue.
Flushing the core isn't much of an option since I'm pretty sure it has a pinhole somewhere. The windows get a haze on them after awhile. It should be changed, but I'm trying to get the winter out of it. I don't have a garage, and the driveway is a cold cold place to work.
What's the best way to bleed the air out?
Thanks.
sometoyotaguy is offline   Reply With Quote
Old 01-22-2010, 09:50 AM   #2 (permalink)
Rip The E Brake's Avatar
Gameroom cash: $112690
View Rip The E Brake's Photo Gallery
Its time to replace the heater core. Its pretty hard to burp the heater core without gettin in there.
Corolla Number TWO
OLD: Corolla 1- 96 4AFE, AE101 w/ 225k Miles orig. motor, 129k trans. - TOTALED.
NEW: Corolla 2- 96 4AFE, AE101 w/ 161k Miles on motor and trans.
Rip The E Brake is offline   Reply With Quote
Old 01-22-2010, 09:54 AM   #3 (permalink)
I'd still have to burp it if I replace it. Is there a usual procedure, or is it supposed to just work itself out?
I'm tempted to try a new thermostat since it looks like they sometimes are weak/bad out of the box.
Thanks
Old 01-22-2010, 12:15 PM   #4 (permalink)
ShawnM's Avatar
View ShawnM's Photo Gallery
Bleeding these older ones is pretty straight forward. Ive never had any issues with just letting it run with the cap off till the radiator fan kicks on. The air usually just works its way out. I you think you still have air trapped in there you can elevate the front of the car during the bleeding process since air will make its way to the highest point in the system.
--Shawn
03 Camry LE
97 Lincoln MarkVIII LSC
67 Mustang
ShawnM is offline   Reply With Quote
Old 01-22-2010, 07:43 PM   #5 (permalink)
Bitter's Avatar
Gameroom cash: $558900
View Bitter's Photo Gallery
somtimes holding a fast engine speed with the cap off for a minute or two will get the air purged out, hold like 2500 rpm for 1-3 minutes and see if you get some air out.
Old 01-22-2010, 11:31 PM   #6 (permalink)
Andele, andele!
speedy25's Avatar
Gameroom cash: $235545
View speedy25's Photo Gallery
Its not air trapped in the heater core, its corrosion!
No heat output because its blocked. Sometimes a flush can help, but usually since the cores passages are much smaller than the adiators, they just stay plugged.
Sorry to give you the bad news in January!
-SP
Old 01-26-2010, 09:23 PM   #7 (permalink)
View fast68's Photo Gallery
time for new core regardless.
bleeding them is never an issue
if there is leaking then its bad
and if theres no heat then either the blend door is stuck inside the box assembly
or the core is junk
if you know that the door inside the box moves when you move the selector from heat to a/c then the core will be the culprit
many 1987 toy truck parts, lots of parts inside and out, also have many '88 pickup parts still.. try me! pm or email me, also fastr68 on yahoo messenger anytime 24/7 signed in on there.
fast68 is offline   Reply With Quote
