DIY Front Bumper Fog Lights with HID's Corolla 93 - 97 - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-22-2010, 08:53 PM   #1 (permalink)
CorollaCarClub.proboards.
RinconRolla98's Avatar
View RinconRolla98's Photo Gallery
Exclamation DIY Front Bumper Fog Lights with HID's Corolla 93 - 97
This is a DIY of a front bumper fog lights using Ford Focus fog lights .
These fog lights are from a 2000 - 2004 Ford Focus . The reason I used these are because there are cheaper and under $25.00 shipped new .
These HID's are 3000k , bulb # 899 .
This is what my front end looked like before I added the fog lights .
First you remove the grille . The BLUE arrows are where the screws are to remove the grille . The RED arrows are where the bolts are located to remove the bumper .
Once you remove the grille you will expose two 10m bolts near the head lights and problaby 2 snaps that hold the top part .
Behind the headlights under the wheel well is one 10m on each side . All you have to do is raise the front end and use a mini ratchet , That way you dont have to take the front tire off , Then you go to the three in the front on the bottom of the bumper .
Once you have the bumper you place it on a blanket so it doesn't get scratched or if yours isnt painted then you can just lay it on a flat surface . Then you get a dremel either air or electric .
[img]
http://4.bp.blogspot.com/_Q2B2pa6pitU/S1o1GZ_SLzI/AAAAAAAAARY/ypQlAIPYbzk/s1600/fogs93011.jpg[/img]
Then with the dremel you cut the four areas , Measure the area before you cut . Then you do the same to the other side .
Once you cut out the piece of the bottom grille then you place the fog light and check to see if any trimming needs to be down . In my case I had to trim the top part some so that the fog light fit snug .
Then I purchased 2 angle hinge from Walmart and had some self tapping screws and screwed one to the fog light on a part that was sticking out . I used some silicone to make sure it stuck .
Then I put a dab of silicone then placed the hinge in it and screwed to self tapping screw . Making sure the corner of the fog light was flushed before I screwed them down .
Then turn it around to make sure it is secure and doesnt shake . If you noticed there is a little space but that doesn't bother me . Then you do the other side .
Then this is what it should look like when you are finished . Then you move on to putting your HID's on .
First you find a secure place on your car to put the ballast . If you have to add some silicone on the back before you screw it so that it prevents it from shaking or getting loose . ( Warning - A loose shaking ballast will eventually burn out your ballast and then you want to blame e-bay for being cheap . )
In this photo I slid the negative wire and screwed it to the bolt where the RED then
Where I made a hole . There is nothing there to worry about drilling into . Once I made the hole then I passed the positve wire .
Then I located my rear window defroster fused and placed the postive wire on one side of the fuse . The Red arrow is where it is located .
Since my rear defogger isn't working I used that button as my on and off button . If you can't use this then you can use a toggle switch and place the toggle switch to where it is comfortable for you .
Then you make sure all your wires are secure and then bolt up your front bumper and this is what it should look like .
Then you test out your lights to make sure they warm up to the yellow and then you are finished .
RinconRolla98 is offline   Reply With Quote
The Following 2 Users Say Thank You to RinconRolla98 For This Useful Post:
Rip The E Brake (01-23-2010), TI-CAVA (01-23-2010)
Old 01-24-2010, 12:03 AM   #2 (permalink)
DOHC VTEC
View Nusdogg's Photo Gallery
Holy crap, this is awesome! Great job man.
204whp/157wtq
Nusdogg is offline   Reply With Quote
Old 01-24-2010, 12:58 AM   #3 (permalink)
Rip The E Brake's Avatar
Gameroom cash: $112690
View Rip The E Brake's Photo Gallery
I may do the fog lights, but not the HID's. Good DIY though.
BTW. you should turn your sticky up top in a whole DIY content thread.
Corolla Number TWO
OLD: Corolla 1- 96 4AFE, AE101 w/ 225k Miles orig. motor, 129k trans. - TOTALED.
NEW: Corolla 2- 96 4AFE, AE101 w/ 161k Miles on motor and trans.
Rip The E Brake is offline   Reply With Quote
Old 01-24-2010, 02:24 PM   #4 (permalink)
Thanks but I'am making a page of DIY , Its not finished yet as I build I add some old DIY's .. SOme things I will put in TN but others will stay on my page ... Feel free to pass it around . LINK >> http://rinconrolla98.blogspot.com/
Old 05-27-2010, 12:34 PM   #5 (permalink)
View Zain's Photo Gallery
which HID kit u used
n how much it cost u
Zain is offline   Reply With Quote
Old 05-27-2010, 09:55 PM   #6 (permalink)
View Strokd_GE's Photo Gallery
Pretty neat man.. Good right up
Hey are those depo headlights with the housings painted?
-Tad
Strokd_GE is offline   Reply With Quote
