Vacuum problem in valve cover - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-31-2010, 08:33 PM   #1 (permalink)
View Relic23's Photo Gallery
94 corolla. I had the oil cap off and the engine on and oil was flying out from the hole in the valve cover. Shouldn't there be a vacuum. There is also a loud noice comin from inside the valve cover.
Relic23 is offline   Reply With Quote
Old 01-31-2010, 09:01 PM   #2 (permalink)
Official TN Toaster
iToaster's Avatar
Gameroom cash: $348795
View iToaster's Photo Gallery
The vacuum is in the intake (because that's where the engine sucks the air in), not the valve cover. Oil will spew out of it because the oil pump is forcing it up there. That noise is probably the cam shafts opening and closing the valves. Everything is as it should be.
1995 Corolla DX - 7A-FE - 5 Speed - 8K1
2000 Celica GT-S - Supercharged 2ZZ-GE - 6 Speed - 3P0
RIP white Corolla
iToaster is online now   Reply With Quote
Old 01-31-2010, 09:07 PM   #3 (permalink)
The Great One!
View jelly53's Photo Gallery
yup, during the oil change I opened up the cap while the engine was running to put some Motor Flush, and the oil started coming out.
97 Corolla CE 5speed
03 Honda s2000
09 Ninja 250r
jelly53 is offline   Reply With Quote
Old 01-31-2010, 09:21 PM   #4 (permalink)
Certified Yo'Mama-ologist
Hook's Avatar
View Hook's Photo Gallery
ummm...you're supposed to put the flush with the engine off, then start up and let it idle for however long the instructions say, before you switch off and drain the old oil.
That way you don't make a mess of things or risk burning yourself with hot oil.
Hook is offline   Reply With Quote
Old 01-31-2010, 09:25 PM   #5 (permalink)
The Great One!
ya I knew that LOL...... but I figured if put it in while the engine was running....it would mix in better.... but it didnt work out!
03 Honda s2000
09 Ninja 250r
Old 02-01-2010, 06:42 AM   #6 (permalink)
Andele, andele!
speedy25's Avatar
Gameroom cash: $235545
View speedy25's Photo Gallery
There is nothing pressurized just under the valve cover. Oil splashes out because there is a pool of it under the cover and the spinning cams splash it around. The small amount of vacuum created by the PCV system is more than overcome by the large oil cap hole.
-SP
Old 02-21-2010, 12:31 AM   #7 (permalink)
View fast68's Photo Gallery
some engines wont run or run very well when the cap is removed, i have found... many times in the past.
some toyotas i know.....
and others..
many 1987 toy truck parts, lots of parts inside and out, also have many '88 pickup parts still.. try me! pm or email me, also fastr68 on yahoo messenger anytime 24/7 signed in on there.
fast68 is offline   Reply With Quote
Old 02-21-2010, 03:07 AM   #8 (permalink)
BoyYota's Avatar
Gameroom cash: $138400
View BoyYota's Photo Gallery
I saw a guy tell a story once, think it was on the Nissan forums or maybe VW forums (I've had a lot of cars), how he ran his car without the oil cap on (by accident--woops!(?)). He said 'well now I know that running without an oil cap on will destroy an engine!' D'oh! I know that you weren't doing long term, but still, this isn't some diesel military application, you don't change the oil with the engine running!
94 Prizm LSi 1.8. Auto and still quick as hell.
BoyYota is offline   Reply With Quote
