DIY Timing Belt Change 93-97 Corolla - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-31-2010, 10:42 PM   #1 (permalink)
Rip The E Brake's Avatar
Gameroom cash: $112690
View Rip The E Brake's Photo Gallery
gen 7 DIY Timing Belt Change 93-97 Corolla
Took this from Autozone.com and uploaded it to my server.
Enjoy people..
http://www.856media.com/corolladocs/...beltchange.htm
Corolla Number TWO
OLD: Corolla 1- 96 4AFE, AE101 w/ 225k Miles orig. motor, 129k trans. - TOTALED.
NEW: Corolla 2- 96 4AFE, AE101 w/ 161k Miles on motor and trans.
Rip The E Brake is offline   Reply With Quote
Old 02-01-2010, 06:38 AM   #2 (permalink)
Andele, andele!
speedy25's Avatar
Gameroom cash: $235545
View speedy25's Photo Gallery
I suppose its information but its confusing. Why do they show TWO sets of timing marks? Once at the beginning and another down the page, Why do they tell you to take off the cam pulleys? There is no reason to except to replace the seals..... WHICH THEY DONT MENTION but the crank seal gets hard as a rock after so many years of soaking in hot oil.
I forget but doesnt the valve cover "lock" a part of the belt cover when you put it on? Or am I mixing up car parts again! I would put the valve cover on last.
Just some thoughts on my end.
-SP
Old 02-09-2010, 09:03 AM   #3 (permalink)
View 93geoprizm's Photo Gallery
interesting, BTW im bout to hit the 150K mark, i know you do this around the 60K mark, when are you supposed to do it again? 120K?
93geoprizm is offline   Reply With Quote
Old 02-09-2010, 09:43 AM   #4 (permalink)
Certified Yo'Mama-ologist
Hook's Avatar
View Hook's Photo Gallery
Methinx it's at 100,000km mark...which yeah, is about the 60,000mi mark
Interestingly enough, it's slightly different for the 20Valve guys, cuz I keep seeing stuff here about cam timing being off and car won't start etc. Unlike the ST 20V, the BT 20V is NOT a non-inteference engine so timing needs to be spot on before you try to turn it over.
There are two cam timing marks to be followed. One on each cam that lines up with the marks on the valve cover, and another set on each cam that are supposed to line up with each other once the top marks like up with the cover (fig.1) while down below, the mark on the timing belt gear lines up with the mark on the oil unit body (fig.2).
fig. 1
fig.2
Hook is offline   Reply With Quote
Old 03-15-2010, 10:55 PM   #5 (permalink)
View keithcrandall's Photo Gallery
In the Autozone Manual why are there two different instruction sets, one with one cam gear and one further down that shows 2 cam gears? Which one is mine if I have a 1997 1.6L base model? Any one else confused by this?
keithcrandall is offline   Reply With Quote
Old 03-15-2010, 11:11 PM   #6 (permalink)
PatrickGSR94's Avatar
View PatrickGSR94's Photo Gallery
All Toyota engines with a "FE" engine designation have one cam gear only, with the other camshaft driven via internal scissor gears. The "GE" engines have 2 cam gears. I usually think of the FE engines as "fake" DOHC :P
PatrickGSR94 is offline   Reply With Quote
Old 03-15-2010, 11:58 PM   #7 (permalink)
Sine Deviance's Avatar
View Sine Deviance's Photo Gallery
Jeez, it's a lot of friggin' work just to get to the timing belt, let alone change it.
'94 Corolla DX Wagon - 1.8L 7A-FE - 4-spd A/T - Phillips CrystalVision 5000k Headlamps - 15" MB Vipers wrapped in Falken Sincera SN-828 185/65 R15's
http://sinedeviance.co.cc/
Sine Deviance is offline   Reply With Quote
Old 03-16-2010, 12:53 AM   #8 (permalink)
Full Throttle
Kiwi-Corolla's Avatar
Gameroom cash: $953415
iTrader Score: 16 reviews
I just went to my local Toyota dealership and they had the whole kit in stock.
Old 03-16-2010, 09:39 AM   #9 (permalink)
That guide covers 4A-GE engines (2 cam gears) as well as 4A-FE and 7A-FE engines (single cam gear). The latter was in 93-97 US Corollas. Other markets, as well as older US Corollas, had various versions of the 4A-GE engine.
