Ok a quick reply here would be very helpful.
I finally(after three days of stubborn bolts and nuts, completely rusted in pins and breaking 2 breaker bars) managed to get the one axle out and the other will be out right away. I already pulled one seal and just wanna make sure I do this right the first time.
I managed to instantly forget which way the seal came out. But since I still have one to pull out I will know soon which side goes in first. But if you could still tell me that'd be great. Ex. The side with the spring goes into the tranny first. Or the side with the spring will face outwards towards the axle?
And I want to sand the rust off of the axle very carefully correct?
And I don't have the tool for pushing in the seal but heard it can be done by hand. Or using a large socket. How far do I wanna push it in. I heard the word flush a lot, but flush with which part of the seal?
the seal I bought has no sort of lip that prevents you from pushing it in too far so just wanna make sure.
Thanks!
Ok So when I pulled the passenger side shaft I noticed that the seal was slightly unflush with the transmission(pushed in too far) Is that the kind of thing that would cause it too leak? The seals I pulled really don't look all that different from the brand new ones. So would improper installation of them cause the leak?
Well I figured it out. But already forked up my seal with the tool I was using
I was so close to having it in there too.
And once again I'm editing:
I bought a seal tool and a new seal. Hammered it in the best i could get it. It was a little crooked. Maybe a mm in on the bottom and a mm out on the top. Is that probably gonna leak?? or be OK
And would the seal being seated tooo far in cause leaking? I'm just trying to figure out why the seals weren't working in the first place?
Thanks for your time,
Rudy
