rear bearings... - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-08-2010, 08:30 PM   #1 (permalink)
View elrich_d's Photo Gallery
rear bearings...
car in question 96 corolla.
needs rear bearing done. Tried to find a diy no luck. Does the bearing have to pressed out from the hub? i know you have to take out the 4 bolts behind the hub. Im assuming the hub and bearing then come out TOGETHER right? Is there a way to use a puller from parts source (canadian) to seperate
thanks guys
elrich_d is offline   Reply With Quote
Old 02-08-2010, 09:50 PM   #2 (permalink)
Bitter's Avatar
Gameroom cash: $558900
View Bitter's Photo Gallery
you can buy it as a whole unit ready to install, just take the brake drum off, take the 4 bolts that hold it off, take the old bearing off (may be stuck with crud, small whap with something knocks it loose), put the new one on, tighten the bolts (not sure the spec), put the drum on, and voila!
The Following User Says Thank You to Bitter For This Useful Post:
BoyYota (02-08-2010)
Old 02-08-2010, 09:55 PM   #3 (permalink)
BoyYota's Avatar
Gameroom cash: $138400
View BoyYota's Photo Gallery
I like this. Dad says he hears a sound in the rear of my Prizm that he believes to be a wheel bearing. Easy fix.
BoyYota is offline   Reply With Quote
Old 02-09-2010, 04:48 AM   #4 (permalink)
Bitter's Avatar
Old 02-09-2010, 06:19 PM   #5 (permalink)
any idea wherei can buy as a whole unit?
Old 02-09-2010, 07:40 PM   #6 (permalink)
Bitter's Avatar
i got mine at pepboys, about $100 each. might be less if you don't have ABS.
Old 02-09-2010, 08:09 PM   #7 (permalink)
Rip The E Brake's Avatar
Gameroom cash: $112690
View Rip The E Brake's Photo Gallery
They are pressed in, so you need to get them pressed out. Just take the parts to a shop if you don't have the tool, and they should press them out and then put them in for like $15.
Corolla Number TWO
OLD: Corolla 1- 96 4AFE, AE101 w/ 225k Miles orig. motor, 129k trans. - TOTALED.
NEW: Corolla 2- 96 4AFE, AE101 w/ 161k Miles on motor and trans.
Rip The E Brake is offline   Reply With Quote
Old 02-09-2010, 08:47 PM   #8 (permalink)
Bitter's Avatar
mine that i took off the car were a sealed solid unit, though they do have ones that can be rebuilt. its hit or miss as to what your car will have on it, but most i've seen have been the non-rebuildable ones.
i think you're thinking of front bearings.
Old 02-09-2010, 08:52 PM   #9 (permalink)
Your right, I was thinking fronts. My b.
Corolla Number TWO
Old 02-09-2010, 08:53 PM   #10 (permalink)
www.rockauto.com will have them I am sure.
Corolla Number TWO
