They will bill you for atleast 3.
It is something you can do, with a floor jack, a razor and a ratchet.
Drain the fluid through the allen drain bolt, if equipped.
Retorque drain plug to 36 foot pounds
Remove the 10mm bolts around the perimeter of the transmission pan.
Drop the pan and remaining fluid.
Clean the pan with brake parts cleaner or equivalent, do NOT use a lint producing rag, let it air dry or use a MICROFIBER RAG
Install a new cork gasket, NO sealant and reinstall pan with bolts torqued to 43 inch pounds.
Refill transmission fluid with 3-4 quarts fluid. Check level once warmed up and adjust if necessary.
Corolla Number TWO
OLD: Corolla 1- 96 4AFE, AE101 w/ 225k Miles orig. motor, 129k trans. - TOTALED.
NEW: Corolla 2- 96 4AFE, AE101 w/ 161k Miles on motor and trans.
