Originally Posted by Bitter
false, old fluid will just keep making it worse. people say that because they wait until there is already a problem to change the fluid, think the new fluid will fix the damage, the blame the fluid change rather than fess up to the fact that they neglected it. or they use the wrong kind of fluid.
There is also this theory...
With the fluid that is already in there, all the seals are conditioned to it, but with new fluid, it may dislodge some stuck particles or grime and allow it to travel into other components like hydraulic areas or clutch discs, etc... so both are true to a certain extent, right?
Edit, and yes, that is the filter kit I use on my car... have at it., remember to scrape away all of the previous gasket, AND DONT THROW AWAY THE SMALL MAGNETS IN THE PAN. Give the pan a good scrubbing. I clean mine with brake cleaner, then scrub it with hot soap and water, microfiber towl dry (a regular terry cloth will leave particles when you goto dry it) then brake clean again and microfiber again.
When putting the gasket on, lay it on the pan, stick the corner bolts thru from the bottom, through the gasket, to hold it in place. You may need a second person to hold the pan up, while you try to tighten the pan
